Power Supply and ATX mods
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power Supply and ATX mods
Hey guys.
I was wondering if I should cut my power supply 24 pin and 8 pin CPU header shorter.
Would that make a difference in speed of power and resistance to motherboard?
But I figure that if my thinking was correct. I wouldnt be the engineer behind the scenes. And due to my thoughts that is why I am not an engineer haha.
I figure if I trim the wires shorter, there will be power send faster to the motherboard?
Or in addition, I was thinking of soldering all 24 pins to the board as well. Instead of simply plugging it in.
What do you think?
Do you guys have any tips or tricks for power supply MODS that you would care to share?
Message edited by ubuntun00b on 11-07-2008 at 05:22:58 AM
Sponsored Links
I have seen case mods with custom made power cables made to exact lengths. It looks good but it will not do anything for speed of power and resistance because the cables are extremely short. It's normally done for cable management and bling.
Reply to JohnnyLucky
soldering them to the board might not offer any performance gain, but it will give you the benefit of it being a son of a b!tch to replace.
------------------------------ They call me crazy for yelling, alone in my room, at the computer screen. They just don\\\\\\\'t understand the game.
Reply to jeremyrailton
jeremyrailton wrote :
...... give you the benefit of it being a son of a b!tch to replace.
Damn the way you said that made me laugh haha.
I was thinking about that. lol.
I guess right there is almost reason enough not to do it.
Message edited by ubuntun00b on 11-07-2008 at 05:47:34 AM
Reply to ubuntun00b
Google "ATX Pin Remover" for the right tool for the job (glorified punch)
http://www.frozencpu.com/cat/l3/g1 [...] Page1.html
forget the soldering idea unless you are trying to fit the entire system into a very tiny space, and need to remove as much as possible. re-tip the leads when you cut them short making new ATX headers at any length you want to no ill-effect.
On the other hand, if you make them as short as possible, you could turn your power supply into a psuedo modular unit by making / buying ATX extensions to do the same thing.
------------------------------ If you don't know what OS/2 is, you don't understand.
Reply to rockbyter
Do not cut them and do not solder them.
Snap out of it.
By that I mean your temporary insanity.
Reply to Zorg
Just remember modifying the PSU will void it's warranty.
Reply to bobbknight
It doesn't matter how fast the power gets from the PSU to the mobo, so long as enough of it gets there!
Reply to mi1ez
Assorted +1s, notably to Zorg. Of all the mods to consider on a PC, this is not the one.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Silverstone makes short cables for some of their PSUs:
PP03 was created for users who wish to utilize the powerful Strider ST60F, ST75F, ST85F in their smaller cases or systems without the added clutter of long cables. This cable set can also be used by any current ST60F, ST75F, ST85F owner who wishes to have a greater choice in the length of connections for their various components
http://www.silverstonetek.com/prod [...] 3&area=usa
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply and ATX mods
There are 767 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
