i ordered a 880W psu with my new computer...
ill have a :
4870 x2
300gb velociraptor
q6600
x48 mobo
1 dvd burner
4gb RAM 1066 mhz...
is 880W enough to power up all that?
If you want to add a second HD 4870X2 later, try getting a PSU that appears on that list with "2" in the "number of cards" column. E.g. Antec Quattro 1000W, Enermax Galaxy EGX1000EWL-DXX, OCZ EliteXstream 1000, PC Power and Cooling Turbo Cool 1200W, etc.
A 550W is sufficient for one 4870x2. 880W is more than sufficient for one.
The PCIe refers to the number of 6 and 8 pin connectors available on the PSU.
what about a 4870x2 and a 4870 in crossfire? or a 4870x2 and a 4850 would it handle those?
that will be fine for a 4870x2 and a 4870 in crossfire just remember that if you get a 4870x2 and a 4850 the 4850 will have to be the 1gig one or it will cut back the memory on the 4870x2 to 512 not unless they changed it
i would add if you can get a corsair for the same price in ur country go for that
