Tom's Hardware > Forum > Motherboards & Memory > Memory > Memory caused problem with sound card
Forum Motherboards & Memory : Memory - Memory caused problem with sound card
I just added memory to my computer (Dell deminsion 8400, vista). After installation it would completely boot up and then it would make a loud niose and then reboot. It worked fine in safe mode. I messed with it for a while and found that if i went into device manager and disabled my sound card (sound blaster 5.1 i think) it would run just fine everything worked. Any suggestions on how to fix the problem between the memory and sound card. Also if i remove the memory the sound works fine.
Message edited by kunsr on 12-08-2008 at 10:11:40 PM
Sponsored Links
kunsr do you have on board sound that you could try.or just move sound card to another pci slot and try that.hope this helps you out.
Reply to major53
The onboard works fine and did try and change slots i even re-installed all drivers i tried to up date my bios to see if that might help but vista won't let me run the program.
Reply to kunsr
kunsr the ram that you added was it the same as what you already had in pc? also how many ram slots does the mobo have and are they color coded.
Message edited by major53 on 12-09-2008 at 02:07:02 AM
Reply to major53
It has four slots for a total of 4gb i already had 2 1gb in and i added 2 more yes there the same even ordered them from dell.
Reply to kunsr
kunsr try just putting the two new ram in and see if it will boot up ok,one of the new ram could be the problem.
Reply to major53
There are 573 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
