Tom's Hardware > Forum > Homebuilt Systems > New System Build > Im newbie building my first system HELP!!
Forum Homebuilt Systems : New System Build - Im newbie building my first system HELP!!
http://www.pricegrabber.com/ulists [...] b5d17ceb20
That's the link to my build. I was wondering if everything was compatible and if it was for a good price. Also if I'm missing anything. I'm also not sure if i should get a fan because i don't plan to overclock for a while. If you have any other suggestions please tell me. Even if everything is fine I would also like to know that. This is for $1600. I see i have over 100 views and no one has helped me yet. If I am doing something wrong please tell me. I am a noob first time ever doing this so please give me some suggestions. Here's my e-mail because it looks like no1 is answering me here dsolash@yahoo.com.
Mobo:
MSI K9A2 CF-F
GPU:
VisionTek Radeon 4870
CPU:
AMD Phenom 9850 Quad
OS:
Vista Ultimate 64-bit
RAM:
Corsair 4GB PC2-6400 DDR2
Case:
Antec 900
PSU:
700w OCZ GameXStream
Monitor:
Gateway FHD2400
HDD:
150GB WD Raptor X
Disk Drive:
LG DVD-RW CDROM-RW combo
complete details for disk drive:
http://www.newegg.com/Product/Prod [...] _-27136149
Message edited by dsolash on 08-22-2008 at 08:18:29 PM
Sponsored Links
Looks good, but could be better. For starters, look up 790GX & SB750 which is the best Phenom overclocker. Yes, even beats out 790FX. The board you picked out WAS the best. The onboard gpu can be disabled in bios.
ASUS M3A78-T
BIOSTAR TFORCE TA790GX
GIGABYTE GA-MA790GP-DS4H
Not familiar with the LCD. Could be good.
You might wanna throw in an aftermarket cpu coola if you plan to o/c the Phenom which is notorious for being hot.
Reply to auscanzukus
- 0 +
Hi dsolash,
I would recommend the Gigabyte DS3/4 series motherboards. My one performs very nicely. Good things have been said about Asus boards. Try to steer clear of boards with onboard graphics if you are buying a graphics card - one less thing to complicate matters when you build.
Try a Corsair PSU, very reliable and stable systems. You will probably need 600ish watts.
You may find that the data rates of new hard drives (eg seagate 7200.11) out does that of a WD raptor. Not entirely sure, use the HDD charts on Tom's Hardware to find out. You will probably end up with more capacity and certainly less noise and heat. (Raptors are prone to needing damping due to vibrations).
There are good options available on Intel CPU's, the general thoughts are that they still out perform AMD based systems. (Hotly debated of course!) Look at a E8400 for gaming or a Q6600 or Q9xxx if you would prefer a quad based system. Pairing that with a P45 motherboard will make a very nice combination.
Hope this is useful.
Jeremy
Reply to jpdykes
There are 1254 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
