Yes No
Ads
Tom's Hardware > Forum > Overclocking > Motherboards > GA-EP45T EXTREME > Q9550 4.5GHZ!!!!
Forum Overclocking : Motherboards GA-EP45T EXTREME > Q9550 4.5GHZ!!!!
Hi all, recently got my new build up and running, full spec is:
700w OCZ
GA-EP45T Extreme
Q9550 E0 (cooled with TRUE120 push/pull)
2x2GB G.Skill RipJaw DDR3
Sapphire 5850 (1050/1200)
Anyway i hit 4.2ghz pretty easily with most things on auto, whilst testing for my max fsb limit im able to hit 4.5ghz without too much effort. The problem is i can only run it sensibly at 4.2ghz, im having to set the vcore in the bios to 1.400v (cpu-z reports it in windows at 1.38v just outside the intel reccomended volts).
I think with everything setup on the other options correctly i could lower my vcore and get the higher fsb i know i can reach. Im not familiar with some of the options in here, if someone with more know how can help me that would be great.
Here are my settings in BIOS now (prime stable at 8 hours, havnt run it any longer yet):
MIT
RGB > AUTO
CPU Clock Ratio > 8x
Fine CPU Clock Ratio > +0.5
Frequency > 4.2GHZ
**** Clock Chip Control ****
CPU Host Control > Enabled
CPU Host Frequency > 495MHZ
PCI Express > 100MHZ
C.I.A.2 > Disabled
**** Advanced Clock Control ****
CPU Clock Drive 800mv
PCI Express Clock Drive > 900mv
CPU Clock Skew > 0ps
MCH Clock Skew > 0ps
**** DRAM Performance Control ****
Performance Enhance > Turbo
X.M.P > Disabled
MCH Frequency Latch > AUTO
SPD > 2.66D
Memory Frequency > 1320MHZ (8-8-8-24-2T)
**** Mother Board Voltage Control ****
CPU VCORE > 1.40000v
CPU Termination > AUTO
CPU PLL > AUTO
MCH Core > 1.400V
MCH Reference > AUTO
ICH I/O > 1.600V
DRAM Voltage > 1.660V
DRAM Termination > AUTO
CH-A DATA VREF > AUTO
CH-B DATA VREF > AUTO
CH-A Address VREF > AUTO
CH-B Address VREF > AUTO
Advanced BIOS Configurations
CIE > Enabled
C2/C2E State Support > Disabled
C4/C4E State Support > Disabled
EIST > Enabled
Im also using Bios F4 (the latest full stable one).
Thanks in advance for any help anyone can give me, im sure i can get the same/better overclock with less vcore, i just need to know what to change to do this.
Cheers!
Reply to djvibes2007
Intel's recommended maximum voltage is 1.3625 volts. Intel's absolute recommended max is 1.45 volts. So you are good there.
I doubt if you are going to do any better with less vcore and still keep it stable.
Reply to jsc
There are 1646 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this be a good build to overclock 2500k to 5.0GHz?
By DJDeCiBeL, 19 hours ago:
I'm the one that told him that a Silver Arrow will get to 5Ghz, so I'll take the blame...
Best offers
Top experts
