I'm still rather confused about what changes I have to make to the default BIOS. I'm using watercooling for my CPU (and GPU) so I don't worry about heat to much.
So far I've got:
- FSB speed
- CPU external clock multiplier
- Memory timing
FSB: I have DDR2 800 Dual Channel RAM so I should run up to 400 MHz FSB whilst the MoBo supports 400 MHz (=1600/4), the CPU is set to 333 MHz (=1333/4) as standart but should run 400 MHz just fine
So I checked the BIOS and it lets me choose a FSB from 200-800 MHz but I can't choose the voltage. Is the voltage regulated automatically to meet the power needs of the system settings or am I missing something?
