Hello,
I have an 8gb Relay flash drive. Called up instruction from Internet. Tried to load on J drive. OK up to point where it says Back up. Nothing happened. J drive does not show any files copied. What did wrong? How to correct?
If you want to put something on the flash drive, just save it to that drive (J), the same way you would a normal hard drive. You can even drag and drop files on the flash drive.
Hello,
what you used to back up? do u just copy the files to flash drive for backup?
