Prime95 problem
Forum Overclocking : General Discussions - Prime95 problem
I built a new computer recently, and I was thinking of overclocking it. I'm a total beginner though.
Specs are:
i7 920
asrock x58 extreme
ocz 6gb gold ddr3 1600
I have been trying to test the stability of my system before trying to overclock it. Using Prime95, I can run one hour on the small ffts before I stop it, but when I try to run the blend test, half of the workers encounter errors due to hardware failure within 10 seconds and just stops the test. All my BIOS settings are at default. I have been playing a few games and nothing really goes wrong when I play however. So..., any ideas?
Message edited by king421 on 11-02-2009 at 03:52:34 AM
Sponsored Links
I don't understand: if Prime95 already fails even before you've overclocked the CPU, then your 920 may have some defects or issues!
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
I have the EXACT same problem with the EXACT same specs. I honestly believe it may be the OCZ Ram refusing to play nicely with the MB. For some reason the memory will not get stable no matter what settings are used.
I RMA'ed the RAM and have ordered some G.Skill 1600 instead. It should be in tomorrow so I'll give it a try and let you know the results.
Reply to blotkis
Yeah, I think it's the RAM too. Going to play with it a little bit more though.
Reply to king421
Did you make sure your ram is getting enough volts? Sometimes you have to manually increase the voltage for what they were designed for. (1.65) What is the ram divider set to? What does it say it's running at in bios? You could be having problems if your ram is running above spec.
Message quoted 1 times
Message edited by cory1234 on 11-04-2009 at 01:26:01 AM
------------------------------ Q6600 @ 9x333, 500gb barracuda 7200.10
Gigabye DS3R P35, Evga 8800 gt
4x1gb Super Talent 800 3-3-4-8, OCZ 850w, Win 7 64
Reply to cory1234
Just backing up what Cory said here.
Difference between Blend and SmallFFT is RAM usage.
I'd be looking at RAM voltage myself first.
------------------------------ Intel E8500 - 4.26Ghz - 533 x 8 - on air cooling with DDR2-1066 running native
Sapphire Ati HD4850
Reply to SpidersWeb
I'd also be looking at ram voltage, when I built my new rig a week ago, I noticed that my ram was running at only 1.5V when its rated at 1.6V. Im also using OCZ ram.
I'd also suggest manualy setting the latency timings, could help with stability.
Reply to omgitzfatal
If smallFFT is passing, the CPU core is OK. The blend test also tests the memory controller and RAM. The memory controller is overclocked, since you're running at 1600, so my guess is that either the memory controller or the RAM needs more voltage.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Just to update, I replaced the OCZ RAM today w/ G.Skill 1600 and EVERYTHING is stable. Passed Prime95 for several hours (as opposed to failing w/in seconds w/ the OCZ) and I think that the RAM was 100% the problem bc it doesn't get stable w/ this board.
Reply to blotkis
UPDATE 2:
I also ran Memtest86+ last night for 8 passes (around 8 hours) and when I woke up this morning there were zero errors and everything was stable (even after overclocking the CPU to 3.2).
If anyone else is having this problem I'd recommend replacing the RAM. This is what I purchased:
http://www.newegg.com/Product/Prod [...] 6820231225
Reply to blotkis
Good work mate.
But did you check the RAM voltage before replacing? Default I beleive is 1.5 and posts above indicate it should be at 1.6V, which will cause instability with memory if not changed.
Glad to hear it's resolved though :)
Sapphire Ati HD4850
Reply to SpidersWeb
Hmm, thanks for the replies but I managed to find BIOS settings that work fine for now. I'm going to do some longer runs later but here they are.
BCLK - 180
DDR Freq - 1288mhz
Timings - 8-8-8-24(tRAS)-88(tRFC) Rest auto
DDR Volts - 1.654
QPI/VTT - 1.34 (not sure what this one was)
Spread Spec - OFF
HT - OFF
Thermal Throttle -OFF
Speed Step - OFF
Virtual Tech - OFF
Without V-drop
Cpu multi - 20
Cpu Vcore - 1.30
Uncore - 2880
PLL - Auto
Everything else under there Auto
It just seems that Asrock x58 extreme and OCZ Gold 6gb ram doesn't like each other very much. Also does turning all those settings off affect performance significantly or durability?
Message edited by king421 on 11-20-2009 at 03:43:46 PM
Reply to king421
Tom's Hardware > Forum > Overclocking > General Discussions > Prime95 problem
There are 965 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
