Tom's Hardware > Forum > CPU & Components > Other Components > Monitor switch with audio, mic, and usb?
Forum CPU & Components : Other Components - Monitor switch with audio, mic, and usb?
Hello, I'm new to Tom's Hardware, so i don't know if this is the right place place to post this, please correct me if its not.
I recently purchased a cord that allows my xbox 360 to be plugged into my monitor. I use the same headset for my Xbox and pc, the Turtle Beach Earforce X1 (http://www.turtlebeach.com/products/efx1/home.aspx). I want a switch that allows me to switch the video and all the headset cables between my xbox 360 and pc. I have seen plenty of these, but the main problem is that the headset needs a USB connector to work. Does anyone know of a switch that has a usb port, vga, audio, and mic swap?
Edit: I just stupidly realized that the switch i posted doesn't have video swapping, reworded.
Message edited by Texterminator on 11-10-2008 at 06:01:36 PM
Sponsored Links
i will suggest you go for Best Monitor switch
Reply to smartvm
There are 997 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
