having trouble setup remote desktop from my laptop running xp pro sp3
to eq660 modem and then through wrt54g2 linksys router to pc running xp pro which on a lan
Sponsored Links
what sort of errors are you getting?
Reply to montyuk
will not connect i think something in route but wanted some to walk through to double check what i have done.
Reply to dannyrobbins
- 0 +
Check WAN IPs with http://www.whatismyip.com Try running the ping command to see if IP is responding. Check to see if remote desktop ports are forwarded by both routers. Then check to see if remote desktop ports are blocked by ISP.
Message edited by lyleb on 03-14-2009 at 10:29:53 PM
Reply to lyleb
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Help with networking
There are 1029 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
