Hy guys I have a problem I started game and my pc screen gone black I tryed to restart it and boot menu goes allright and that win loading screen after that black screen I went in safe mode unninstalled my graphic drivers omega drivers(ati x1950pro) restarted and it functioned xp loaded after that Iv tryed downloading new drivers from net installed them same problem,tryed drivers wich Iv got with my graphic card again the same...I reinstalled my windows nothing...but works without graphic drivers...
It sounds like a failing PSU to me.
Could you post your full systems specs?
------------------------------If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
I've seen this issue with video cards as well... check the fan if it's not using passive heat displacement and make sure it is spinning (it should also spin freely if you flick it with your finger.)
I've had several video cards that I caught in the early phase of overheating when their cheap $.20 cooling fans seized up. The card would work fine in 2d when the 3d hardware wasn't in use but it would go 'black' as you put it when you launched anything that required OpenGL or Direct3d.
Intel iselton motherboard DG965
Intel core duo 3.0 ghz
Ati Gecube x1950 pro
2 gb ddr2 800 mhz takeMS
160 gb wd1600JS disk
650 W gembird it costed about 40 euros
Is it possible that the game put your video card into a screen resolution that your monitor doesn't support? Then, when your computer reboots it starts out at VGA res (which you can see), and switches to this unsupported res when you login (which you can't see). So if you boot into VGA-only safe mode, uninstall the graphics drivers, and clean out any registry entries relating to the graphics drivers, and then reinstall (after another reboot), that might be enough to get your GPU's output showing up on your monitor again.
------------------------------Pentium D 940 w/XP90C
D955XBK,2 x 1 GB PC5300 @ 4-4-4-12
HIS HD2600XT
4 x 400 GB WD4000YR RE2 (1TB RAID5, 125GB RAID0)
Reply to TeraMedia
You mean by installing drivers just simpely install the drivers by executing the .exe file you downloaded from the internet or using the tool in control panel? ( control panel-system-advanced-hardware ).
yup I install drivers after I down it its all OK then my pc restarts and after loading screen there is nothing screen goes black after that my pc restarts and all over again
