Guys I need major help. I have been working on this build for over a week and I can't get it to work. I have tried two motherboards, two cpu's, and two sets of ram. No combination of the parts I have will boot and I can't figure out what is bad.
Here are my parts
2x1Gb corsair dominator 1066 ram
2x2Gb G.Skill 1066 ram
Asus P5Q motherboard
Gigabyte GA-EPU43-DS3L motherboard
TWO E8400 CPU's
Visiontek 4870
Corsair 750TX PSU
Xigmatek HDT-S1283 Heatsink
I have tried booting outside of my case with a motherboard, CPU, heatsink, one stick of ram, video card, and my PSU and no combination of the above parts works. Every time I jump the power leads with a screw driver to power the system on the heatsink fan, video card fan, and PSU fan start to spin, but right after they start they stop and the computer shuts down. It is almost an instant on off situation.
I figured it could be my PSU now that I have tried TWO of every other key part so I bought a Coolmax PS-224 PSU tester. When I use this tester the power supply turns on and gives good readings for every voltage accept my +5VSB which gives me a reading of "LL" for no or extremely low voltage detected. Could this be my problem? Could I have multiple dead parts? Am I experiencing good parts that are just incompatible? Does the motherboard need more than just the heatsink fan plugged in to run or will it power off because no other fans are plugged in?
What really has me in a jam is that the computer acts like it wants to start up. In the very beggining a week ago I tried to boot this for the first time with two sticks of the G.Skill. It failed and I tried with just one stick of G.Skill. It worked and I thought I was home free, but after I powered my system off and removed two case fans it would not start again and since then I have not been able to make this system boot.
I am just about at my witts end here. As you can see I can almost build two computers but no matter what parts combination I get the same results. I really appreciate the previouse help that I got here and I thank everyone who replys to this thread to help make this bane of my computing life a thing of the past.
Here are my parts
TWO E8400 CPU's
Visiontek 4870
Corsair 750TX PSU
