Tom's Hardware > Forum > Homebuilt Systems > New System Build > New Gaming Rig Cooling/Power Question
Forum Homebuilt Systems : New System Build - New Gaming Rig Cooling/Power Question
Hi guys. This is my first time posting here! You all seem pretty educated about building new rigs so I have a question about cooling and power for you.
I need to replace my ancient (2001) PC and I decided to go with a not-top-of-the-line-but-close system that I'll build from scratch with parts bought on Newegg. Oddly when I built this system (P4 2.4 CPU and 9800 pro radeon) I barely had to consider power or cooling needs and now I read these forums and shake with the fear of melting parts :)
I'm not made of money so I decided to get a system one step down from the top guys out there. I'll be getting a 8800 GTS instead of a 9 series nVidia and will be settling for a Q6600 on the processor front. That being said I have NO IDEA how much power these parts will slurp up and no clue on how many fans/sinks I will need on the CPU and video card. I also would love a case recommendation. As a pure utilitarian, I prefer it to BE cool not LOOK cool.
If it helps answer power questions I can say that only a single DVD-R drive, a 500GB 7200 WD HD, and maybe a soundblaster card will be sharing the power load. I'm not going RAID or anything.
If you guys could help me that would be awesome. Who would have thought the damned case and some fans would be the hardest choice I have to make?
Sponsored Links
The gpu more or less determines the wattage.
Quote :
Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 26 Amp Amps.)
Minimum 450 Watt for SLI mode system.
Actually will always be lower than recommended. Pick out a Corsair, Antec or OCZ psu.
As for cases, look into Coolermaster 690. Cools the best for the price.
Reply to auscanzukus
Your description is about 5 steps down not one :)
You do not want an 8800GTS. You want a 4850.
This is a complete list I made recently. It includes a case/PSU combo deal and a monitor.... Not all discounts are listed, the full build would be under 1300 after shipping but there are rebates too.
https://secure.newegg.com/WishList/ [...] D=10498008
Message edited by Proximon on 08-26-2008 at 03:17:39 PM
Reply to Proximon
There are 1146 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
