As per my usual tendencies, I always build new systems in hopes that I will later just upgrade certain aspects. But 90% of the time I end up just building a new PC all together. Oh well.
Anyway, I just recently bought a BenQ V2400W 24" LCD and my current setup struggles whilst running games at 1920x1200. I mainly game and just general PC usage with some web/graphic design mixed in on occassion. This is what I'm looking at:
Motherboard: ASUS P5Q Pro
CPU: Intel Core 2 Duo E8600
CPU Fan: ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
Video: 2x CF'd SAPPHIRE 100242TXSR Radeon Toxic HD 4850
RAM: 2x kits for a total of 8gb - A-DATA 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
I'm planning on doing some OC'ing. I'm hoping to get 8gb of RAM on this board. Will the A-DATA cut it?
Storage isn't an issue and I currently have an Antec P182 which I really love. I am taking suggestions on cases, but will probably just stick with the P182. I am in need of a new PSU, something that will work well with the P182 (I had issues with past PSU's reaching everything needed inside this case) and will support CrossFire. I'll be running a vLite'd version of Vista Ultimate 64-bit.
Any feedback is appreciated!
Message edited by df1z on 08-25-2008 at 10:33:40 AM
- Drop to E8400 because if you are overclocking you will make up the difference in clock speed to an E8600 and you will save yourself money ($100).
- For overclocking look at a 4GB of DDR2-1066 from Corsair, Geil, OCZ, Mushkin. The quantity is not so important, and 4Gb is the sweet spot, whereas extra speed will help you.
- The money saved on the processor could upgrade one of those 4850's to a 4870. Although you would need another 4870 to crossfire. You might find that one 4870 would cope with the 24".
- PSU, suggest Corsair 750TX. Should be about right for your needs.
Jeremy
Message edited by jpdykes on 08-25-2008 at 01:09:20 PM
-1 on the Zalman cooler.its utterly expensive and with inadaquate performance.get the Xigmatek S1283 or the OCZ Vendetta 2 for better performance at a even lower price.
Excellent! Thanks for the input guys. I think I may just stick with the CF'd 4850s for now. And for the PSU I was looking into a modular unit. I just built a system for a buddy and used my first modular PSU and it was just a much cleaner setup. Any thoughts?
This is a revised outlook:
CPU: Intel Core 2 Duo E8400
CPU Fan: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
RAM: CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5DF
On the topic of PSUs, I was looking at the Antec NeoPower 650 or the Antec TPQ-850 850W. I've never had any problems in the past with Antec PSUs. Anybody have experience with either of these?
The TPQ 850 is a pretty good deal, comes with a combo deal on a good case.
Corsair 750TX is highly recommended around here, and a good deal as well.
PC P&C has a 610W that is a pretty good deal, and OCZ has two 600W that are good as well. I think the Neo is probably good but not as good as the others listed.
There is hardly any performance difference between 800MHz RAM and 1066MHz RAM, and unless you plan on a ridiculous OC on that E8400, 800MHz is all you need.
