Problem with audio
Hello,
i have 1 pc hp dx7300,after this pc format ...i can't to install audio driver..so, until now i can't play my music...
6 answers Last reply
More about problem audio
  1. to khubani..i was install this driver..but failed...i was format 3 times and isntall agains this driver...but still failed..
  2. What OS is on the system now? When it failed, what messages did you see?
    Run the BIOS update, then the chipset drivers, then the audio drivers.
  3. I would hold off on the BIOS update, unless necessary.
    It sounds like the audio was working before, so the current BIOS version should be fine with the onboard audio. The reason I say to hold off on the BIOS update, is because a bad BIOS flash can turn your motherboard into a paper weight.
    OS XP PRO SP3
    after install...no messages ..just choise to restart..and after restart,,still audio driver not istall at device manager..can u tell me the step start install driver for this pc...
  5. Go to this link:
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3251400&prodTypeId=12454&prodSeriesId=3251396&swLang=13&taskId=135&swEnvOID=1093#113165
    And download the Realtek High-Definition Audio Driver.
    Once it's downloaded, extract the files, and run the setup file.
Drivers Audio Hewlett Packard Format Windows XP
