will the Bitspower Ultimate G 1/4 Thread 3/8" ID x 5/8" OD Compression Fittings work with a swiftech 320 rad? im not sure if the rad has g 1/4" threads, i think its 3/8" NPT threaded hubs...will it still work?
My 320s were NPT threads. I think Swiftech was going to switch to G1/4 on them at some point, but I got some nylon G1/4 and tighly inserted them into the NPT threads. Works great...not sure how well it will work with metal threads though...
The MCR320 uses a combination of brass tubes and copper cooling fins for improved cooling. They also use a patent pending end tank design with 3/8" NPT fittings for improved flow and system bleeding. The radiator has a nice gloss black finish with just the edges of the cooling fins painted. This leaves the majority of the copper cooling fins exposed for improved heat dissipation.
I picked mine up from Petra's over a year ago. Maybe they were part of outdated stock and they were trying to get rid of them. Either way, the guy from Petra's called me within 2 minutes of posting my order and told me they were NPT rather than G1/4, so I got different fittings.
I would assume the new 320's are G1/4 now...? That would make logical sense with every other fitting being G1/4 now...
