Tom's Hardware > Forum > CPU & Components > CPUs > Thermal compound clog!! help!
Forum CPU & Components : CPUs - Thermal compound clog!! help!
My cousin has an AMD X2 4400 and he had a water block on it where the tank was leaking outside the case so he took that off and removed the processor but he got thermal compound on the pins of his processor, which he cleaned (no idea how he did that) but now he also has thermal compound inside the socket!!! - any idea how to clean that out properly without damaging anything?
Thanks a bunch.
Sponsored Links
I never had that problem, but I would open the clip and hose it out with a can of plastic safe residue free contact cleaner. The can with the tube attached.
Test it to be sure it's plastic safe and don't get the cleaner that has lubricant, because obviously it's not residue free.
Be sure to use safety glasses/googles, as it will spray back in your eyes, and do it outside.
Reply to Zorg
- 0 +
unplug the mobo, isopropyl alcohol + Q-tip, allow to dry THOUROGHLY, problem solved
------------------------------ GA-965P-DS3 - e6420@3.3 - 2GB OCZ Reaper pc-6400 - WD Raptor X - 9600gt - OCZ GameXStream 700W - SB Audigy 2ZS Platinum - Thermaltake Tsunami Dream black
Reply to shoota
- 0 +
Zorg's method is probably the best, as isopropyll alcohol may not be able to get the goop out of the holes. Since whatever you use may need to be applied with some pressure, you'll probably need to take the mobo out of the case, and probably hold it on edge.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
- 0 +
thanks for a quick response guys. case closed.
------------------------------ Latest Rig:
Q6600 OC 3.33 || Abit IX38 OC 1900 || 4x1GB DDR2-800 OC 950 OCZ Ati Cert || 2x2900Pro OC 800/1700 || ABS Tagan ITZ 800w 20A 6 rails || 1TB HD Space || 21" CRT for 2048x1536 resolutions. Yummy. || XClio A380-PLUS: 2x250mm fan + 1x360mm fan
Reply to korsen
There are 648 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
