Hello i bought a sapphire 4870x2 today and i got disappointed , . the reason is: when i had my 4870 i got avg 270 fps at high settings at Counter strike source , while i got avg 140 fps at high setting with my new sapphire 4870x2," both stresstest were at 800x600 ingame resolution".
my pc specs when i did both stresstest was as follow:
First of all, your power supply is two weak. A 550W is really the recommended supply for ONE 4870. Your card is probably not getting enough juice. Also, crossfire adds some processing overhead to your CPU so you mighnt wanna think about overclocking your chip. You also need more system RAM. I mean really you have more VRAM than system RAM!
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
what are your catalyst settings and why the hell are you testing at such a silly res, would it not be better to use a real world test and use the native res and max settings?
------------------------------I'm a git, deal with it.
apart from the overclocking nonsense(seriously wtf), he is right about the ram and power supply, i was leaving those out till you checked what catalyst settigs you were using and made sure anything obvious wasn't different.
Going from a 4870 to a 4870X2 isnt much of an "upgrade" when you factor in your PC specs and resolution. At that resolution even a 7900GT will give you like 200FPS in Counter Strike....you were already way...way....WAY on overkill as far as video card goes for CS with the 4870. Of course this is assuming CS is the only game you play. And has somebody already mentioned, anything over 60FPS is unnoticable and is preety much headroom for spikes and heavy graphical areas.
As far as teh rest of the system goes, I think hes ok with 550W but his PSU is an ASUS, so yea I wouldnt trust it. If it was a Corsair, PCP&C/OCZ, Mushkin, Antec or what not he would be fine with it. Also ditto on the above RAM comments, 2gb for XP, 4gb for Vista.
I think its a waste to answer this thread. Too many loony moves, I question the OP as to the seriousness of this post
------------------------------I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
Your PSU should be fine to be honest(if it holds its specs). at 260ish watts there should be enough for the low power use system you have left.
For real though, get more memory 1 gig is not enough for much any more. Hell my PVR uses 600-700megs with all its other stuff it does in the background and that thing NEVER games.
My system(only 1 4870,but there is still plenty of room left for more)
You won't see too many (or any) reviews with this card at 800x 600 but one pattern you may notice is top end cards under performing lower models at CPU bound resolutions. You may have no problem with your card but I agree with the gallery that the first set of specs you presented are very unbalanced and the PSU doesn't meet the requirements.
Buying another 4870X2 for QuadCrossfire sure as hell wont help your "issue". That will do nothing but make it worse. Dont waste the money, a single 4870X2 is good enough for anybody and anything.
Reply to jaydeejohn
highest settings? what do you mean? everything forced to high?
also, 1GB is really not enough, some will doubt it's benefit but i would say always run it in dual channel if possible so 1.5GB per channel if running 3gigs.
