Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Case Fan Switches? Easy Question (I hope)
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Case Fan Switches? Easy Question (I hope)
The case I purchased for my first DIY PC Build came with 2 already attached case fans. They both have a switch, L-M-H, am I supposed to set these at whatever my required setting is and then just leave them inside the case? Or am I supposed to be able to somehow use them when everything is put together? I don't see any slots or access holes for this to happen.
Antec 300
http://www.newegg.com/Product/Prod [...] -_-text-_-
Sponsored Links
Yes, you can use the switches to manually set fan speed. I do not know about mounting the switches though. I can't recall anyone posting a smiliar question. Anything in the user's manual?
Reply to JohnnyLucky
Nope. Just says they are for fan speed. I guess they just hang out inside with all the other cables. Maybe I'll mess with the case in the future to mount on the outside somehow.
Thanks for confirming what I already thought.
Reply to jessegibson
Toms Hardware just did a review of 13 mid-tower cases. The link to the article is still on the home page. The Antec 300 did very well. I took a look at the close up photos. The switches just dangle inside the case.
Message edited by JohnnyLucky on 11-14-2008 at 08:30:23 AM
Thanks for furthering the confirmation. That case was recommended by a couple posters and I bought 2 days before that review came out. Needless to say I was stoked that I picked the one they were recommending.
There are 615 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
