I have built a system, which booted fine, installed windows etc. Didn't have any stability issues when running tests.
It did however have some issues booting, i.e. it took multiple resets before it would get past POST.
The problem seems to have changed to something less random, now it will only boot with the default settings. If I so much as change the time in BIOS, it won't boot.
I've tested with other memory, and PCI graphics, but neither seem to make a difference.
I'm hoping it's just some setting that I need to change in BIOS, as the hardware all seems to work fine under load, once I get it to boot.
So, if anyone has experience with similar hardware, or a similar issue, or any ideas...
Components:
Asus p5k-e/wifi
Core 2 Duo E8400 (w/Scythe ninja mini)
Corsair XMS2-6400 2x1gb
Asus HD4850
No DVD or HDD currently plugged in.
Thanks in advance,
Matt
Components:
Asus p5k-e/wifi
Asus HD4850
Thanks in advance,
Matt
