Well, generally the rule with overclocking and cool and quiet is that you would turn it off before hand. Unfortunately it's been awhile since I've OC'd anything but a black edition. So you can check out this if you want: http://www.tomshardware.com/review [...] 452-4.html Did you get yourself an aftermarket heatsink and fan or are you using the stock?
------------------------------Phenom II X4 955 @ 3.82 (Zalman 9900)
asus 780v mobo
4gb Corsair DDR2 800
MSI HD4870 1gb @ 822 core
Reply to Cgintz
i would rather undervolt the CPU but my mobo doesnt seem to have the option (or i can;t find it)
so i want to underclock it instead, but it is conflicting with CnQ. the CPU wont' automatically change to underclock the CPU when idle in windows. so the CPU ends up using more watts instead.....
------------------------------Athlon II X3 425
Asus M3A78-EM
4GB 800mhz Dual Channel DDR2
1.5TB WD HDD
Reply to expxe
