Tom's Hardware > Forum > Overclocking > General Discussions > Problems Overclocking
Forum Overclocking : General Discussions - Problems Overclocking
I have having radom reboots after I tried overclocking my computer. It was working fine for a couple of days with several hours of Prime95 stability, but I then tried running memtest86 for stability and ran into a few problems. I worked on moving the memory around until I got full memory stability for over 8 hrs. After I got memory stability I started getting random reboots once I was in Windows 7. I got to looking at my voltages and I noticed in CPU-Z it show my CPU voltage between 1.36 and 1.376, but I have it set at 1.4 in the bios. Could this be part of the random reboots in Windows? Below are my system specs please let me know if you need any more information.
GIGABYTE GA-EP45T-UD3LR
Intel Pentium E5300
OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Seagate Barracuda 7200.12 500GB
OCZ StealthXStream OCZ700SXS 700W
Antec Three Hundred Illusion
POWERCOLOR HD 4870 1GB
Sponsored Links
What you are seeing is an example of "voltage droop". Google it. Less than .05 volts droop is not unusual. It is not the cause of your system instability.
Reply to jsc
I just tried uping the voltage 1 more notch and my voltage is still at 1.376. My main problem is when I first open windows it restarts 3 or 4 times before it is stable enough to run for a little while. I only have this overclocked to 3.0ghz currently. I had this stable tested at 3.33ghz before. Do you know what I should try testing first? (motherboard, memory, powersupply)
Reply to dman220
If Windows restarts several times, you have a problem with stability somewhere.
Are you using the stock cooler? At around 3GHz, the stock Q66000 cooler becomes inadequate.
Reply to jsc
Q6600? I thought he had a Pentium Dual E5300?
Reply to Bluescreendeath
Yes I have a e5300 not a Q6600. I have even tried just switching to 333 fsb to run at 2.66 ghz from the stock 2.6 ghz and 200 fsb and had problems with stability. I switched back to stock to make sure I do not have just a basic stability problem, but everything seems to be working fine at stock settings.
Reply to dman220
I have another update. I can get my computer to run at 3.5 ghz with stability when I put one stick of memory in, it does not matter which one they are both stable. When I put both sticks of memory in, it doesn't matter if it is in duel channel or single channel. Would this mean I have a memory problem or a motherboard problem?
Reply to dman220
:( I have no idea where the "Q66000" came from.
I do not know how the Gigabyte Core2 "T" motherboards handle the DDR3 memory timing.
I have a GA-EP35-DS3P running an E5200 at 3.78 GHz. (315 MHz X 12). I took the Memory multiplier off AUTO and set it to 2.00 for a mem clock of 730 MHz.
If you are running an AUTO setting there, try changing it.
Reply to jsc
I am running on a single memory stick right now at 3.5 GHZ (333mhz x 10.5). I took the memory multiplier off Auto and set it to 4.0B? (the one for 333 fsb). The memory runs at 1333mhz. My memory is listed to run at 1600mhz.
Reply to dman220
Core2 CPU benefit very little from overclocking memory. Try dropping your memory multiplier to maximize your CPU speed.
Reply to jsc
There are 470 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
