Hey everyone!
My computer has recently started crashing on me after roughly 20 minutes in any game. I've had this rig for over three months and have gamed a lot on it prior to the recent crashing issues and I've run numerous tests on the memory and power supply and they both check out so I'm thinking it's heat related. It has been quite warm where I live lately and these crashes have coincided with the warmest of the weather, not to mention I have been able to game for longer periods of time by cranking the a/c all the way, putting the computer closer (live in an apartment with just a window mounted a/c) to the a/c itself and turning all the fans to high.... this of course is a pain but is all evidence towards the problem being heat... so with that in mind how do I cool my system down?
My system:
-Coolermaster Cosmos S with three 120mm top mounted exhaust fans, one 120mm rear mounted exhaust, one side 200mm intake, one front 120mm intake, one bottom 120mm intake (so I'm getting lots of air circulation) SpeedFan puts the "Aux" idling at 34C.
-Intel E8400 (reduced to stock speed of 3GHz in my journey to find the root of the problem) with a Noctua NH-U12P cpu cooler in a push pull config, SpeedFan puts the CPU idling at 33C with Core 0 at 43C and Core 1 at 23C
-EVGA 750i FTW Motherboard (Thinking this is the culprit) known for it's hot north and southbridge, SpeedFan says the "System" is running at 120C from start up and it doesn't waver (so I'm thinking this is a glitch) also it has the "Temp" (I'm thinking northbridge) idling at 54C, I can get this number as low as 50C using the complicated air conditioning method mentioned above but it just ramps up during gameplay and after an instant alt tab from 10 minutes of TF2 the "Temp" was at 59C. Temp 1 in SpeedFan has never been too high hovering under 50C with an idle of 40C.
-Geforce 9800GTX overclocked graphics card (usually use 2 in SLI, took one out when during the investigation faze), there is warm air coming from the back of the card (as normal) and it idles at 54C according to Riva Tuner which I don't think is so bad for a graphics card.
Not sure if the rest are related to heat:
-Corsair TX750W PSU bottom mounted with fresh air intake
-4GB Crucial Ballistix memory (set it to 4-4-4-12 timings, everything else not overclocked) I'm using a Antec Spot Cool aimed at the memory as well.
-500GB Seagate Barracuda 7200.11, one of the intake fans blows over the HD cage.
-Lite-on DVD-RW
-Scythe Fan controller
So do you guys agree with me that it's heat related? How should I fix the problem? Swap in different chipset heat sinks? Would that be a big job? What would you recommend for Northbridge and Southbridge heat sinks (keeping in mind I live in Canada and not everything is available here)? Or should I wait for winter?
Any help would be much appreciated.
My system:
-Lite-on DVD-RW
