I got all my parts yesterday, and spent several hours putting everything together, finally turned it on....and some things seemed to work, and some didn't:
the good:
-system powered up, cpu and case fan turned on, no burning smells or anything like that.
the bad:
-nothing is showing up on the monitor at all
some things I've done so far:
-checked monitor by plugging into different source
-tried both dvi and vga on graphics card
-tried different combinations of unplugging the various drives, i.e. running without floppy, or cd, etc.
-used jumper to reset the mobo to factory specs
-tested keyboard on different source
other things to note:
-monitor seems to recognize video connection is there, but shows message that it's going into sleep mode
-based on mouse not lighting up, usb ports don't appear to be working (mouse does light up when connected through ps/2 converter)
-keyboard, using ps/2 converter, is not responsive as far as i can tell - e.g. caps lock light doesn't turn on.
-reset button doesn't seem to have any effect, at least none that i can see without a working display.
at this point, the only thing I can think of to try, before starting to swap out parts, is move the ram into a different slot or try a different stick of ram. i would like to think the graphics card is to blame, but lack of usb responsiveness makes me think it's a more severe problem.
any thoughts or suggestions would be greatly appreciated!
not getting any beep. not sure what you mean by cpu connector (this is my first build). is this a power connector that should be somewhere close to the CPU?
if so, I think I might know what the problem is. The gigabyte directions were a little confusing...they mentioned 2 different power connections, and I couldn't figure out if I was supposed to plug both in, or just one of them. and i didn't want to overdo it, so I just did one of them. the one that i did plug in was a 24 pin connection.
one other thing to note about the 8-pin connector, even if your psu only has the 4-pin connector, it'll still work. the other 4 pins are extra power for very electricity hungry cpu's, mostly extreme edition processors.
Haha, yeah. Those additional pins are for the CPU only. No CPU power = lights and fans spinning... but nothing else. The 24 pin is for just your motherboard peripherals (sound, chipsets, PCI-E and PCI busses, USB, etc.)
where there no instructions with your case as to where the connections go from the psu..???
when one buys a stand alone psu there is usually some kind of info supplied showing where the connectors go/match up,at least my two psu's did enermax and ocz....
thanks again rgeist, for reminding me that powering up the CPU is a good idea.
here's where I'm at now: computer boots up but I can't get the keyboard to work. this is a usb keyboard, but I'm also trying it with a PS/2 converter. it's not working either way.
thoughts? Right now the only thing I can think of is to try a real PS/2 keyboard and see if that makes a difference.
You can try a true PS/2 keyboard and see if that works. If not, try different USB slots. (You probably know this as well, but make sure your keyboard is plugged in before you power the machine on. Some boards won't recognize a keyboard if its plugged in after the machine has started up and POST'ed)
-keyboard didn't work at all through ps/2 converter.
-keyboard in usb didn't work with old-school dos boot .
-keyboard in usb DID allow me to get into the BIOs. From there, I saw that usb keyboard and mouse was disabled. I enabled them, and everything worked from there. I'm posting this from the new computer now.
