hello
am using c2d e8400
xfx 9800 gt 512 mb
asus p5ql pro mobo
4 gb normal ram
320 hdd
using cooler master extreme 500 w
is that enough for the specs??
and sometimes i can hear electric buzzing sound from my psu i believe.... even after computer is turned off
what is the problem?
Sponsored Links
well you can check for dust bunnies or you can bench the innards and chase down the problem from there..:)
Reply to dokk2
Buzzing comes from a malfunctioning PSU.
Replace it.
To be on safe side go with something with more power too.
This one is decent.
http://www.newegg.com/Product/Prod [...] 6817703005
Get a unit with Active PFC
I recommend a unit with a single 12v rail; but if you find something that costs a little less with multiple rails make sure that all of the 12v rails supply at least 18 amps.
Antec, PC Power & Cooling and silverstone are good PSU manufacturers.
Reply to ravenware
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > psu problem....need help please
There are 1030 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
