Alright, so I just got a new XFX 750i Mobo. I previously had a Asus P5K-Deluxe. I moved everything from my old system onto this new mobo, but have a few problems.
1. A red LED light near the 'Front Panel Header' connections is on steadily and the number next to it is 'LED1 R474'. I've looked around and haven't found anything. I'm not expecting this to be a big problem, just maybe that it's expecting something else to be connected when I only have three things; Power Switch, Reset Swtich and HDD Activity LED.
2. No display on my monitor. I'm using a 8600GT with DVI, worked perfectly on my other computer but for some reason not now. The MOBO is running fine otherwise... CPU working right, fans working right, no other red LED's or no sounds. It's starting up like it should, just the GPU isn't outputting anything. I've tried this 8600GT as well as my 9800GX2 and neither show anything no matter what cables I use.
My other specs are:
Q6600 2.4GHz
4GB RAM (only have 2GB in now)
1000W Antec Quattro
500GB SATA HDD
Does anyone know what the trouble could be?
EDIT: I just got done reconnecting EVERYTHING and making sure everything was seated correctly, primarily the GPU. Everything was plugged in fine and still no changes.
EDIT #2: I just got done taking out the new MOBO with EVERYTHING unplugged and the small battery out. I replaced the GPU, CPU, HDD & RAM with the old card and the display popped right up, so it can't be any of those components. Could this just be that the MOBO is bad?
My other specs are:
Q6600 2.4GHz
1000W Antec Quattro
500GB SATA HDD
