Tom's Hardware > Forum > Graphic & Displays > ATI > Sound card sandwiched between 2 radeon hd 4850
Forum Graphic & Displays : ATI - Sound card sandwiched between 2 radeon hd 4850
Hi,
I have 2 radeon 4850 cards stacked on top of each other with the temperature profile loaded to speed up the fans to cool down the temperatures, but I also have an auzentech xplosion 7.1 right in between the two, the temps for the cards are 60C idle and 80 under load, I wanted to know if that would cause an issue for the sound card? would those high temperatures affect the sound card?
Thanks for the help
Sponsored Links
Hah, I'd be more worried about the sound card blocking the airflow to the 4850. As long as you have good ventalation to move that 80C air out of the case then it shouldn't be a problem.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
- 0 +
Id ether go for a large case side fan with cross flow (not diagonal up across CPU, make it go from the bottom of the front to the bottom of the back with the cards via other fan configs) where the case fan sucks it out, or go water cooling. The latter is probably $300, youd have to go 2 gpu coolers, a cpu cooler, and all the gizmos.
Reply to Zanny
I think you may want to rig up better cooling.
Reply to ohiou_grad_06
There are 542 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
