P2Q Q9550 - O/C to 3.2Ghz; X48 MB (prob. Asus Rampage Formula or GA-X48-DS5); 4 x 2GB DDR2 800; HD 4870 (future Crossfire?); 3 x 7200 Sata drives; and the rest
I need about 850W to be safe, and I want to have some upgrade capability down the road. I picked the following PSU's, give me your opinions, or let me know if you recommend something different. If I dump the crossfire idea how much power will you recommend? 700W?
Hiper Type M HPU-4M880 – 135
Xigmatec MC NRP-MC851 850W – 140
Rosewill RX850-S-B – 109
RAIDMAX RX-850SS – 95
SIGMA MONSTER SP850C – 105
Athena Power AP-P4ATX85F12EP – 100
I am leaning toward the Hiper 880W because of price/reviews/power. The Xig is a bit more efficient (according to specs) but not by much. Good decision?
One thing to note with PSUs is that it's the one component you NEVER try to save money on. As such, I suggest going with either Corsair or PC Power & Cooling. Not sure on the reliability of the brands you listed. Hiper were good in the past but don't know about now.
Anyway, a good 750W will keep your system running nicely, even with a future crossfire, maybe not if you cross the 4870 with a 4870X2.
If you really want enough juice for whatever wacky setups, I've heard brilliant things about the 1000W Corsair HX1000. Picking one of those up soon enough myself.
I'm pretty set with the Hiper type m....but....the asus psu calculator is telling me i need at least 1050W of power? How truthfull is this in your opinion? One thing I've noticed is they don't list cards above HD2900, however that shouldn't make too much difference.
So will 880W Hiper be enough? Will it be enough for i7 920 with crossfire and 6X DDR3?
If I have to, I guess I can get something like the Silverstone OP1000-E - $170
Thanks again!!!!
P.S. I'm seriously reconsidering my build for an i7
the PSU calculator is not accurate. A 4870 crossfired actually ran on my other righ with a 620. Total power consumption isn't drawing more than 480watts. I'm running 4850 on crossfire, Q6600 OC'ed on a 550 watt psu. What you see people telling you that you need a 1k psu is a myth and its overated. A 4870x2 crossfire consumes 680watt at load after calculating the effeciency factor.
One thing you should take note of - all your components are connected through the PSU - invest a little in quality PSUs.
The 880w is fine for your build. Your budget is high enough for an i7 build, i'd sure wait a week or 2 and see more reviews about bugs, drivers, problems etc.
the most important part of any computer IS THE POWER SUPPLY,,this is not the time or place to pinch the almighty moneybuck,you are not only buying for now but for who knows how far down the road and how many upgrades,if you buy cheap there is a very real risk of doing serious damage to a high power system, as a general rule you should not settle for nothing less than 80+% efficency at ful load with at least a 3 year warranty..
Personally i wouldnt go with any of those Sigma, Athena, Raidmax Rosewill All crap basically Xigmatek is the CWT like the 650/750/1000 Corsairs but they cut down on the quality of components so not as good...
Hiper is good, but id still go with a better brand like Antec Signature and Corsair. I currently have used 3 Antec Signatures. I have the 850 and 2 650s. They are very good...a little hot but it handles it all fine
Message edited by Silverion77 on 11-17-2008 at 11:22:02 PM
------------------------------Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
The only psu listed above that I would consider is the Hiper.
All the others are suspect in quality.
All the previous posters have recommended solid alternatives.
I would ask you to consider the following:
PC Power & Cooling 750 After rebates at $99 it is a steal from NewEgg.
More than enough power is available for your needs.
Corsair! I build pc's for friends, neighbors and girlfriends. I use Corsair exclusively. Corsair psu's are rock solid and very stable. Tom's Hardware just did another review of psu's. Corsair did very very well.
