hi i have a P5B mobo a E6750 cpu runs @ rated FSB 1333mhz @ 2.66ghz and ocz memory ddr2 800mhz and a HD5850 video card how can i up the cpu to 3.0ghz or 3.2ghz any help would be great thank you
sry i ment i have to set CPU VCore if i leave it at auto and set CPU frequency to 400 i get about 20 sec before comp turns off from heat i will try vcore @ 1.35v and see temps
wow ok i set my vcore @ 1.35v set fsb to 400mhz running @ 3200mhz now and temps are lower then at 3ghz 45c at idle now 39 to 42 going to run some test and benchmarks be back soon ty all what are good temps and what are bad temps
