I am trying to put together a new system that will primarily be used for photography and video editing (all adobe applications) and gaming. It will also be used with office applications (MS office). However, the big thing that I'm trying to accomplish with the system is to create the most responsive system that I can especially when it comes to photo editing and video editing.
I've been looking at putting together a skulltrail system, but I'm not sure that's the best route to go due to some of the limitations I've been reading (memory limitations - FB-dimm).
I have two 30 inch monitors that I currently use and plan on getting two ATI 4870 x2's to drive those monitors. I'm just not sure what I need to go with when it comes to the motherboard, cpus and RAM - I want to get the components that will provide the most performance for what I want to do. Price doesn't really factor in, I just want the best possible system available today for what I'm trying to do.
Any advice and guidance you guys can give would be great, especially if you are running the adobe applications and doing similar things (Lightroom for photography and adobe suite for video and image editing).
Thanks for your help!
