Problem with 88GT
Forum Graphic & Displays : Graphics Cards - Problem with 88GT
Hi! im new to this forum but ive been tuned in for a few months
this is my rig:
C2Q Q6600 G0 @ 2.5GHZ
eGeforce 88GT @ 715\1800\960 with an Arctic Cooling Accelero S1+FM121
Corsair 2GB (1024X2) XMS2 CL5 (upgrade soon)
Gigabyte GA-P35C-DS3R
HEC Zephyr 650W
250GB 16mb SATA2 WDAAKS2500
HEC 6A21
and i have a problem with display, when in the boot i see lines that are in different colors, and when in OS (Vista Ultimate 64BIT) the colors are 4bit (and it wont let me change the resolution and color depth) and i get pillars in which the picture is scrambled and i cant run any games, OC programs wont recognize my GFX ive tried using both DVI slots, switching monitors, nothing helped...]
thanks in advance
Sponsored Links
Welcome to the forums!
Bad video card.
If overclocked, remove the overclock first.
Message edited by evongugg on 09-24-2008 at 03:15:36 PM
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
but i cant, any overclocking programs wont recognize my GFX is there anyway to reset it? (like CLRCMOS)
Reply to NateXYZS
You shouldn't need to reset a video card.
Just make sure the power is connected and the card is seated.
You could use Rivatuner to change the frequencies.
Reply to evongugg
everything is in place.. problem is.. the visibility sucks at the moment and ive tried RivaTuner but saw no option to change frequencies (used Riva before) if there is an option to reset a video card and it can solve the problem i would like to try it, but ill check riva again just to be sure
Message edited by NateXYZS on 09-24-2008 at 03:25:23 PM
Reply to NateXYZS
- 0 +
you've made sure that the card is firmly seated on the mobo,connected the six pin plug at the back,made sure that the contact fingers on the card are clean,and that there is no junk in the connector,,right??,,can you try it in another system ???,,otherwise replace,you just might have a lemon,,also are you sure of your psu,,is it giving the card the power it needs..:)
Reply to dokk2
yep im pretty sure i double checked it, (a lemon??) i cant try it in another system in this house, but ill have to take the GT for a walk XD (not the first time hehehe) ill check everything again and ill reset the bios just in case, if in the end it wont work.. i guess ill wrap the card up and... i dont want whats after the wrap up..
Reply to NateXYZS
bump bump bump
the problem has been solved partially, i cant change resolution without getting the colors screwed up, and i cant play games, dx9 failure (even DX10) cant watch movies, i got these 4 pillars that everything inside them is shaking constantly
Reply to NateXYZS
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem with 88GT
There are 1104 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
