[#00c638]
Hi, I'm new to Tom's and I was wondering if anyone could help me on a few critical peices of my first ever gaming
PC! I'll list the components I'm considering and I would appreciate your opinions on which is best for gaming and value.
Case:
1st choice: Coolermaster Cosmos 1000
2nd Choice: NZXT Tempest
3rd Choice: Anything Lian Li
CPU:
1st choice: q9550 2.83 ghz
2nd Choice: e8400 3.00 ghz
3rd choice: e8500 3.15 ghz
4th choice: q9450 2.66 ghz
(I want to overclock and keep my proc for the next few years... also want best possible gaming performance for price)
PSU:
1. PC Power and Cooling 750 Watt
2. Corsair TX 750 Watt
3. Thermaltake Toughpower 750 Watt
Mobo:
1. Gigabyte P45E-DS3L (is this a solid board for OCing?)
2. I dont know, maybe ASUS...
(I dont plan on using SLI)
Thanks for reading and I'd really like to hear your opinions!
It's hard for us to give you opinions on value without a budget.
I'd say go for the E8400, whichever case you like, the 4850, or the 4870 (depends on your budget) and the PSU depends on which GPU, though 750 is a lot for only 1 GPU. If you get the 750w, I'd go PCP&C.
The P35/P45 are good boards. I have always had good luck with Gigabyte.
the value type:
Case:anything you like
GPU:l4850 radeon
CPU:E7200or5200
PSU: however 300w enough for most system.
Mobo: intel P45 chipset maybe is only best choice.Gigabyte P45E-DS3L is good enough.
300w will not be enough for a decent gaming machine (especially with power hungry cards).
I'd get an E7200 or an E8400 CPU with an aftermarket cooler.
I'd check out the P45 or the X48 (if you want to crossfire at full bandwidth). P45 is not the only choice.
Go for a 4850 or 4870 (and look to crossfire in the future)
Get the Western Digital 640 GB hard drive.
Get a PSU in the 500w - 750w range - depending on GPU(s) or how much you plan to overclock
Get 2x2GB DDR2 800 RAM (unless you plan on a serious overclock) for a decent price from a good company (Crucial, Corsair, OCZ, Mushkin, etc) with good timings (lower the better: 4-4-4-12, etc).
Come back with some choices and we'll help you out.
Is your $1500 budget for your computer alone? Or are you gonna be buying your monitor, keyboard and such out of that as well?
If the budget is just for the computer you may be able to purchase a 4870x2, which would tear up your games. It however wouldn't be consider the best bang for the buck... If you find that too pricey I'd suggest the 4870.
For the case its your choice, but I personally would suggest the tempest. I love the airflow and looks of it.
I'd go with the corsair TX 750 its a great PSU and you can get it for a really reasonable price with rebate at newegg right now
for the CPU go with the e8400
And for the motherboard, if your certain you not ever going to want to crossfire or SLI, the GIGABYTE GA-EP45-DS3L will work fine.
