I have an hp s3321pc slimline and im looking to update the graphics card so i can actually play higher end games. and of course my computer can only use low profile cards ad i need help on finding one that will let me play games. my current graphics card is a Nvidia geforce 6150SE nforce 430, and it is integrated into my motherboard. i have found a couple of graphics cards that might help but im not sure. i don't wat to spend alot of money, around $150 or below would be good. please help me with this. the graphics cards im looking at are the ati hd 3650 512mb and a 7300 gs. im not sure if these are what im looking for please help. if there are any better low profile cards for gaming please tell me. thanks
Sponsored Links
jaksart does the mobo in that pc have a pci slot or a agp slot
------------------------------ ▐ ASUS RAMPAGE EXTREME II ▐ I7 920 ▐ 3 GIG CORSAIR 1600 ▐ BFG 280 GTX ▐ ANTEC 850 PSU ▐ ANTEC 900 CASE ▐ ACER 22" 2216WB LCD ▐ SAITEK ECLIPSE II ▐ LOGITECH G5 ▐
Reply to major53
- 0 +
im also looking at a x1600pro low profile
http://www.i-store.com.au/product/ [...] uctid=7984
Message edited by jaksart on 09-24-2008 at 10:20:03 PM
Reply to jaksart
- 0 +
jaksart what kind of games are you wanting to play on this pc ?
Reply to major53
- 0 +
i have orange box, bf2. bf2 runs fine orange box, not so great tf2 and half life ep1 and ep 2 dont run well and portal runs worst.
Reply to jaksart
- 0 +
if i can find a decent graphics card im going to get left 4 dead. i also have counter strike source it runs fine except for pixel shader maps
Message edited by jaksart on 09-24-2008 at 10:24:18 PM
Reply to jaksart
- 0 +
jaksart look at this one : http://www.newegg.com/Product/Prod [...] 6814130085
read down about 6 or 7 reviews
Message edited by major53 on 09-24-2008 at 10:32:38 PM
Reply to major53
- 0 +
its not low profile low profile means half height, look at this one in the photo http://www.i-store.com.au/product/ [...] uctid=7984 it is only half as high as other graphics cards only low profile (half height) cards fit in my pci slot
Message edited by jaksart on 09-24-2008 at 10:35:07 PM
Reply to jaksart
- 0 +
jaksart sorry forgot you said low profile.that card should work on all those game you mention.you don't have much space in that case do you.
Reply to major53
- 0 +
no i dont have much space in my case, so the card you think would work is the x1600? before i found that i was looking at hd 3650 512mb http://www.newegg.com/Product/Prod [...] %2bprofile it had DX 10.1 and pixelshader 4 the x1600 only has DX 9 and pixel shader 3
Message edited by jaksart on 09-24-2008 at 10:43:40 PM
Reply to jaksart
- 0 +
jaksart also for what you will pay for that card you could get a 9800gt,but I understand your limits on that pc.that 1600 should work just fine.
Message edited by major53 on 09-24-2008 at 10:43:51 PM
Reply to major53
- 0 +
1600 or 1650, i just want to know what card will work the best for games
Message edited by jaksart on 09-24-2008 at 10:46:17 PM
Reply to jaksart
- 0 +
jaksart that 3650 is a better deal and a better card than the 1600
Reply to major53
- 0 +
really? i thought the 1600 would be better, i heard people say that it was a good low profile gaming card
Reply to jaksart
- 0 +
jaksart did you read the reviews on the 3650 you linked to it will play bf2 also it will play unreal III thats not bad.
Reply to major53
- 0 +
it does look good it also says orange box and call of duty 4 play maxed.
why was the 1600 so much more expensive?
Message edited by jaksart on 09-24-2008 at 10:56:42 PM
Reply to jaksart
- 0 +
jaksart all I can figure is the place you would have brought it from,I bet it's cheaper on newegg.also the next pc you invest in build it yourself,pc's that are pre made are all limited to what you can put in it,and they charge a arm and leg for them.if you can replace a video card you can build a lot more pc for less money.hope this helps you out
Reply to major53
- 0 +
jaksart if you ever play cod4 and you see major53 in a site be easy on me I'm on up in the age and my reflex isn't what it was 20 year ago.hehe
Reply to major53
- 0 +
i don't have cod 4
Reply to jaksart
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Need Graphics Help
There are 1299 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
