Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Need a new monitor for gaming please help
Forum Graphic & Displays : Graphics Cards - Need a new monitor for gaming please help
I have a CRT monitor that is on its last leg. I really haven't dealt much with LCD screens and so I don't have a lot of screen time with them. I will buy a quality monitor but probably not the most expensive thing I can get. I am in the U.S. and will be getting a ~ 22" to 24". I could go up a little or down a little. I am not sold on a particular monitor. I have a fairly decent setup so I am not concerned with my GPU.
Any advice on a good monitor would be appriciated.
Also, besides native resolutions, what specifications should I be most concerned with?
Thanks
Cat
Sponsored Links
Some basic things other than supported resolution/pixel pitch: :p
Response time: lower is better.
Max contrast: higher is better.
Message edited by dagger on 09-25-2008 at 12:37:06 AM
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
In addition to the specifications. One of the best things you can do is go check out the monitors in person at maybe a local retailer.
Specs only mean so much, since picture quality and coloring is a very subjective thing.
Message edited by johnyeah on 09-25-2008 at 12:38:28 AM
------------------------------ "If you don't plan on listening, why ask?"
Reply to johnyeah
If I were you I would consider a HD TV as well. The prices are pretty resonable for the screen size/resolution.
Reply to Rammsie8
- 0 +
I have had good luck with Samsung monitors - they are really high quality. Great for gaming. I have 2 22" monitors now - both Samsung
Reply to huron
- 0 +
Sam's club is selling a Samsung 26" 1080P LCD HDTV for $500. I don't think you can top that. In store only.
Reply to ram1009
- 0 +
One of the most overlooked specs is the horizontal and vertical viewing angle. Cheaper monitors wil have something like 160/160 degrees. A good unit wil have 178/178. What this means to you is that you do not have to keep your head as much centered on the display to avoid a washed out screen.
I think larger is better for games. look for 1920x1200.
I think Samsung makes panels for many vendors. I would look at them first, on the theory that they keep the best panels for themselves.
Reply to geofelt
I had a 22" apple lcd for a few years and loved it. Then I bought a new 24" samsung 2493hm. The only thing I will say is Wow. The difference between them is very apparent. The samsung is much brighter and much clearer. The colors are very nice and the 10000:1 contrast ratio is great. I play my games at 1900x1200 which is the max resolution with three 9800gtx's in triple sli and no matter what the display is always perfect. I would recommend this monitor to anyone looking for a great quality monitor at a good price. I paid $399 for mine.
Reply to jebadiah
Faster the refresh rate the better. For instance 2ms. This referes to how long it takes to refresh the horizontal lines on the screen.
Like it has been said the higher contrast ratio the better.
More Hz the better.
Look for a unit that has HDMI. If it does not have HDMI it is old stock. Besides you want HDMI, it is a better interface than VGA, DVI and RGBy.
If you are looking at the new HD TV's look for 120mhz, $$$
1080i is interleaved. (only reads every other line at any given time usually as a result of converting analog to digital or vice versa)
1080p is progressive. (Reads every line every time. True Digital HD)
VGA always analog
HDMI, DVI digital but not necessarly all the time it depends on your equipment, converters, video card, tuner card.
22" monitor @ 5ms refresh @ $200.00 and the price goes up from there.
Reply to knotknut
cool. Thank you all for your responses. Sounds to me like a lot of you have had good luck with Sammsung. I will definately look at them for my purchase. Any thoughts on Asus or Viewsonic. I have had good luck with Viewsonic CRD's in the past and Asus has a good warranty for thier displays.
Reply to hairycat101
http://www.newegg.com/Product/Prod [...] =W2452T-TF Any thoughts on this one. It looks good from the comments. I'll go to Best Buy to look at the thing in person.
There are 963 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
