G
Guest
Guest
Archived from groups: alt.games.starwarsgalaxies (More info?)
Hello,
This quest is noticable harder than previous combat qests. Does anyone can
tell me how to finish this ? I've get remote for Phy sith base, but dunno
what is best strategy out there. To take full group of ppl with me as
support or do it only with friend? I'm tka/swordsman, and good as tank. Do
you you know how many ppl in group can be rewarded with unlocking melee acc
branch ? I've heard a couple of rumors: 1st - only two ppl in group will get
unclock (the one who will disable the shield, and the one who will capture
the commander), 2nd - number of siths spawning at base entrance depends on
number of ppl in your group.
Anyway I need good tactics for this, especially for 2 mans only.
Regards.
Hello,
Regards.
