Graphic card help
Forum Graphic & Displays : Graphics Cards - Graphic card help
What are the most important characteristics of the graphic card?What should I consider when buying one?
Sponsored Links
It depends on what you are going to be using it for. Gaming? Resolution? Screen size?
The pixel shaders, the memory, the architecture, the speed, etc all play an important part. The drivers are a big issue as well, but we hope that AMD/nVidia is doing their job there.
Reply to huron
First, define what your budget is as well as what your current setup is. If you have a weak setup then you won't be able to get the most out of more powerful cards. Also define what games you want to play and at what settings you would like to play them at. Then, since your on Tom's Hardware, look at the charts to compare them.
http://www.tomshardware.com/charts [...] ks,30.html
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
If youre serious about gaming, 512 mb of memory. DX10 or better. Make sure it has the connections you have or may want in the future DVI HDMI etc. This is just basics, theres alot more to it whwen it comes to performance
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
I wanna use it for gaming.
I can see characteristics of my current card in gpu-z but I dont know what they mean.
So can u just explain what does it mean and how much is immportant for gaming:
1.Memory size
2.GPU Clock
3.Memory clock
4.Bus width
5.Bandwidth
6.Shaders
7.Texture Fillrate
Message edited by aleksaas on 09-25-2008 at 07:17:40 PM
Reply to aleksaas
- 0 +
The most important characteristic of the graphic Card is that it works! If they dont you can not use the computer.
The most important characteristic differs from person to person. Some want the fastest, some its the price/performance ratio, some its only price. For me its price to performance. The HD4800 is around 150-200 depending on where you get it. The HD4850 is $150 at Best Buy now.
1Haplo
Reply to 1HAPLO
- 0 +
1.- The card's "RAM" -> bigger resolutions require more VRAM for textures.
2.- The graphical processor "speed" -> just like in CPUs 1Mhz from ATI is not the same from nVidia. The logic "the more the better" works in the same line of cards: 8800's, 9800's, GTX200's, HD4000's, etc... Or if they share the same architecture (the way they "do" things).
3.- The video card's RAM "speed" -> same logic: the faster the better among types. Different GDDR's have different ways of using that "speed": x1, x2, x4, etc. This alone ain't a hard decisive factor.
4.- The "wideness of the river" -> more bits imply more lanes between the GPU and the VRAM. This alone ain't a hard decisive factor.
5.- "How much water can go trough the river" -> the merge of points 3 and 4 into 1 single metric. This can be a significant point to purchase.
6.- Kinda hard to explain in short, but they are the way the card "paints", "shades" and "sizes" things basically. Lame explanation, but meh...
7.- Processed things the GPU can write in the memory of the card per second. Kinda like saying "done things per second" in the VRAM.
If someone can clear up a few things, it'll be much appreciated, lol.
Anywhoo, if you get too technical, you'll get a headache instead of a video card purchase decision, lol.
Esop!
EDIT: Spelling xP
Message edited by Yuka on 09-25-2008 at 07:44:40 PM
------------------------------ - Athlon64 X2 4400+ @2.4Ghz
- DFI Lanparty UT NF4 SLI-D
- 2Gb (512Mbx4) Corsair XMS 2.5-3-3-7 @440Mhz
- Sapphire HD4850 @650Mhz 512MB GDDR3 @993Mhz (wasn't stable @680Mhz :( )
Reply to Yuka
Thx everybody!It helps a lot!
Reply to aleksaas
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Graphic card help
There are 1127 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
