Hello,
I've recently bought a PowerColor HD 4870 and install it, and as soon as I run Crysys Warhead I've noticed that it is performing very bad! Then I run GPU-Z and keep it active while I play a bit. The problem is that while I play the Core Clock is still 500 Mhz ! It happens also on GRID and Mass Effect; BUT it works fine on Devil May Cry 4 and UT3.
Is There any way I can force the GPU to enter performance mode?
P.S. It's doesn't matter how much I overclock the GPU it still runs on 500 Mhz
My card is PowerColor PCS+ HD 4870 512MB GDDR5 http://www.powercolor.com/eng/products_features.asp?ProductID=2304
