Tom's Hardware > Forum > Homebuilt Systems > New System Build > poker/pro audio/multitask build - please help!
Forum Homebuilt Systems : New System Build - poker/pro audio/multitask build - please help!
Hi all. I'm a "power user" with lots of computer background, but this will be my first build. My budget is about $1500, some parts purchased. I might overclock a bit, though I've never done it before.
I want your help in optimizing my build for (1) performance (2) price, and (3) avoiding headaches, thanks all!
Uses (in order):
  • Poker + Database + Reporting
  • Multitasking + Software development + standard internet/ms word stuff
  • Digital Audio studio
  • Media Server via PS3
  • Occasional games (usually don't play, but I will be forced to do so with a 30" monitor and a modern machine!)
Already purchased:
  • Dell 3007WFP 30" monitor (2560x1600)
  • Samsung Syncmaster 204B (secondary monitor)
  • Seagate Barracuda 7200.11 750GB HDD
  • MBox 2 Digital Audio Interface
  • Korg Kontrol49 Midi Controller Keyboard
Current Build Plan:
MOBO:
GIGABYTE GA-EP45-DS3R LGA 775 Intel P45 ATX Intel Motherboard - Retail ($150)http://www.newegg.com/Product/Prod [...] 6813128344
Comment: I chose P45/DDR2 for price/performance considerations. Any reason to consider DDR3 or X48, or wait for X58?
CPU:
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550 - Retail ($330)
http://www.newegg.com/Product/Prod [...] 6819115041
Comment: I'm pretty convinced I will make full use of quad-core. I run tons of stuff simultaneously.
RAM:
G.SKILL 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Quad Kit Desktop Memory Model F2-6400CL5Q-8GBPQ - Retail ($170)
http://www.newegg.com/Product/Prod [...] 6820231151
Comment: I don't think 8 GB is overkill when I'm working with pro audio apps. But is DDR2 800 wise, or should I get 4 GB of faster DDR3, which will still be useful when I upgrade to i7/X58 or beyond?
OS: Microsoft Windows Vista Ultimate SP1 64-bit English 1pk DSP OEI DVD for System Builders - OEM ($180)
Comment: 64-bit is crucial for supporting my heavy RAM requirements, can't wait. Do I need "Ultimate"?
GPU:
VisionTek 900244 Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail ($285)
http://www.newegg.com/Product/Prod [...] 6814129113
Comment: Games are not important to me, but I'd like to be able to try one or two with this system, preferably at 2560x1600. I know nothing about graphics cards. Is this card overkill? Is it not enough to run at 2560x1600?
Case:
LIAN LI Lancool PC-K7B Aluminum/ SECC ATX Mid Tower Computer Case - Retail ($120; $90 after rebate)
http://www.newegg.com/Product/Prod [...] 6811112154
Comment: Don't care much about case as long as it's quiet-ish and won't cut me up :) I'm not a big fan of flashy LEDs but I assume you can turn them off? Everyone seems to love the Antec 900 for a budget box; is this a better choice?
HDD #1:
Western Digital Raptor WD740ADFD 74GB 10000 RPM SATA 1.5Gb/s Hard Drive - OEM ($150)
http://www.newegg.com/Product/Prod [...] 6822136033
Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM SATA 3.0Gb/s Hard Drive (bare drive) - OEM ($190)
http://www.newegg.com/Product/Prod [...] 6822136296
Comment: Second HDD will be used for data storage; I'll use this one for OS + certain apps that need low latency (e.g. database, audio stuff).
Fan/Heatsink:
Do I need one if I don't overclock? If I do?
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - Retail ($35)
http://www.newegg.com/Product/Prod [...] 6835233003
PSU:
No clue. How much power do I need? What's a good choice? Your help here is appreciated!!
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail ($110, $90 after rebate)
http://www.newegg.com/Product/Prod [...] 6817139005
Thanks in advance for any suggestions you guys have.
Message edited by mike brie on 09-02-2008 at 11:10:35 PM
Sponsored Links
Change the hard disk to a Velociraptor or a WD6400AAKS, depending on budget.
Stick with DDR2.
Upgrade the video card to HD 4870X2, or upgrade the motherboard to GA-X48-DS4 and add a second HD 4870 to the list. 2560x1600 is a challenge for any video card in the world right now. I think the HD 4870X2 is the better solution in your case, because it has more RAM and it's simpler to use with two monitors.
Add a Corsair 750TX PSU.
You can't turn the Antec 900's LEDs off, unless you cut some cables or replace some fans. Check out the RC-690 case instead.
Add a HDT-S1283 if you intend to overclock.
Message edited by aevm on 09-02-2008 at 03:12:16 AM
Reply to aevm
Agreed with Aevm.
The old Raptors are not that fast compared to newer 7200RPM Drives.
I would Recommend getting a 2nd 750GB Drive so you can more easily keep backups on both Drives.
The Velociraptor is signficantly faster than the old Raptors.
If you are not into gaming, Downgrade your GPU to something like the HD4850 or perhaps lower.
The added graphics not only add cost but they add noise and heat.
The money is better spent on better HDDs, SSDs, etc....
And Don't go DDR3, 8gb of DDR2 is perfect.
AEVM picked a good PSU if you Upgrade your Graphics.
If you don't Upgrade, Anything by Corasir, PCP&C, or Seasonic in the 500+ watt range is perfect.
------------------------------ If its good in theory but not in practice,
its not good theory.
Reply to zenmaster
- 0 +
definitely velociraptor fore $190 150gb and about 2 as fast
if you think you can use quad sheer but i would go fore 8400 3.0ghz 6mb cache fore $170
4870 is overkill fore everything but gaming (can be load though)
ddr3 is not much faster than ddr2 and is priced in the stratosphere so go ddr2 (but there is mainboards that support both but they can only support one at a time and have only 2 ddr2 slots)
aftermarket coolers are needed fore overclocking otherwise they can be quieter than box fans (even some passive ones)
psu get 500w or so inless you need headroom fore upgrades
Reply to ke7diz
- 0 +
+1 @zenmaster. Unless you start gaming, you won't need the high powered graphics.
You may find out you'll want to play more though, so may as well be prepared. Aevm picked a good PSU. It's more than you need if you don't add more graphics horsepower, but you can always think of it as an insurance policy.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Excellent suggestions, thank you all!
I'll change to Velociraptor for sure. I didn't realize that they had a 150GB option that is so close in price to the 74GB raptors -- this is a no-brainer, so glad you guys pointed it out, awesome!
Gaming is my lowest possible priority so I may pass on the 4870X2, and even consider downgrading to HD4850 or lower. I'd be perfectly happy waiting 1 year to buy something like the 4870X2 at a cheaper price.
aevm, I like the Xigmatek heatsink you suggested, thanks. I also like the Cooler Master RC-690 case a lot...might actually get this over the Lian Li...
zenmaster, I agree about the backups. I forgot to mention that I have an additional 500GB external drive for backups. However, the Seagate 750GB is so cheap these days that it might be better if I just pick up an identical drive and install it internally (faster backups).
Also forgot to mention that I already have a DVD writer, so I'm covered on that front.
A couple follow-up questions:
If I want to try out some slight overclocking of the CPU and memory, is my motherboard (GA-EP45-DS3R) a good enough choice for it?
Is Vista 64 Ultimate the version I want to run?
Reply to mike brie
- 0 +
Get this bracket too for the HDT-S1283:
http://www.newegg.com/Product/Prod [...] 6835233019
With the GA-EP45-DS3R you should be able to get your Q9550 to 8.5*400MHz i.e. 3.4 GHz without trouble, just using the motherboard's native fsb, no overclocking of the MB or RAM needed.
If you want more than that, you will have to work harder at it, and it might hurt stability. I wouldn't advise it, for somebody who hasn't overclocked before and for a machine used for work.
Vista version: I think your best choices are Ultimate 64-bit and Home Premium 64-bit.
http://www.newegg.com/Product/Prod [...] 6832116493 $110 Premium
http://www.newegg.com/Product/Prod [...] 6832116488 $180 Ultimate
I'd guess you can afford the extra $70, based on the rest of the build. Whether it's worth it in your case, that depends on what you're doing. Compare the features and then decide for yourself.
http://www.microsoft.com/windows/w [...] fault.aspx
Reply to aevm
Sweet, thanks for all the advice aevm.
3.4 GHz would be great so I'll start with FSB overclocking only, which sounds fairly straightforward and yield some nice benefits.
The bracket sounds like a few bucks well-spent so I'll definitely get it as well.
It looks like Vista "Home Premium" is conveniently missing remote desktop functionality, which I want, so I guess I'll go for Ultimate.
I think I'm nearly done. Just need to decide if I want to stick with HD4870, or downgrade further. This will determine the PSU needed; I'm thinking 650-750W if I stick with HD4870?
Message quoted 1 times
Message edited by mike brie on 09-02-2008 at 09:25:05 PM
Reply to mike brie
- 0 +
You've got a weird situation there with your huge monitor. Either you care about games or you don't. You'll have to decide that first. It also depends on the games you like.
These numbers might help you decide. For example I could live with 25 fps in Oblivion or Diablo, but for shooter games I'd want more.
http://www.anandtech.com/video/sho [...] =3341&p=14 CoD4, at 2560x1600, HD 4870 gets 55.7 fps, HD 4850 gets 43 fps.
http://www.anandtech.com/video/sho [...] =3341&p=15 Quake Wars - 61 fps vs 47 fps.
For these two games, I'd say HD 4850 is good enough, and HD 4870 is perfect. (Keep in mind that anything over 60 fps is wasted anyway with a 60Hz refresh rate, so aim for 60 fps.)
http://www.anandtech.com/video/sho [...] =3341&p=17 Witcher: 30 fps vs 21 fps.
http://www.anandtech.com/video/sho [...] =3341&p=19 Oblivion: 26 fps vs 21 fps. These last two are more important differences IMO. 30 fps is pretty smooth for the average eye.
http://www.anandtech.com/video/sho [...] =3341&p=13 Crysis - they didn't even try it at 2560x1600. At 1920x1200, it's about 30 fps vs 25 fps.
Reply to aevm
- 0 +
I missed the PSU part completely.
If you have decided to avoid Crossfire, and the choice is now between one HD 4870, one HD 4850, or something less, then you can get a 650TX PSU for $90 and it's enough.
http://www.newegg.com/Product/Prod [...] &Tpk=650TX
There's also a PC Power & Cooling 610W, same price.
http://www.newegg.com/Product/Prod [...] 6817703005
Normally I'd prefer the PC P&C, at the same price, but the 650TX has 52A instead of 49A and has 6+2-pin connectors instead of plain 6-pin, which makes it more future-proof.
Reply to aevm
- 0 +
i would go 4870. even if those listed games aren't that big of a deal what about 2009 games? maybe something that interests you comes out. 4870 also has a fan i believe so runs cooler than the 4850. rest of the build is set up to last awhile and with that high resolution i don't think 4870 is going to be overkill. and eventhough you can crossfire on p45 board it is on x8/x8 and the one study i have seen (although with only one p45 and one x48 board so not a lot to go on) showed the biggest impact on crossfire was at 2560x1600 resolution. So i wouldn't even consider getting another card down the road eventhough the mobo would let you. it won't help performance enough to be worth the price (even if price comes down). 4870 should allow you the flexibility to try anything on decent settings for at least awhile (crysis doesn't count). :) :)
Reply to bdollar
- 0 +
oh and +1 to the PSU suggestion.
Reply to bdollar
Great info again, I appreciate all the time taken to provide me the links, thank you guys!
I think crossfire won't make much sense for me, either now or in the future, so I'll stick with a 650W PSU, probably the Corsair for the reasons mentioned by aevm, good stuff.
I'm leaning towards the 4870 for the reasons mentioned above. On the other hand, this is probably the most obvious place for me to knock $100 off the total price if I felt like sacrificing a little game performance, which currently means nothing to me, as I only play games on ps3. I think I'll see the total price, and make the call from there.
Thanks again guys, I'm pretty excited that this will be a kick-ass machine for my purposes.
Reply to mike brie
For anyone following this thread, I found out that you can hack Vista Home Premium to support Remote Desktop (including concurrent connections), if you are willing to install a hacked DLL.
http://www.missingremote.com/index [...] Itemid=224
Message edited by mike brie on 09-03-2008 at 02:01:05 AM
Reply to mike brie
- 0 +
#1 That's illegal.
#2 Also immoral. Maybe Microsoft has too much money, sure, but there are millions of people who rely on their investments for retirement, and Microsoft is part of more mutual funds than almost anybody else. You are hurting them too by stealing from Microsoft and encouraging others to do the same.
#3 Maybe the hacked dll monitors what you type and sends your bank account number and password to its authors. That's OK, I guess. I'm sure they are nice people and won't use them.
Reply to aevm
hahaha, I don't think hacking a DLL is illegal but OK, points taken.
For those that are interested in another alternative to RDC that doesn't require using a hacked DLL, have a look at VNC.
Reply to mike brie
There are 822 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
