Tom's Hardware > Forum > Homebuilt Systems > New System Build > Power Supply.. how do you know?
Hi, newbie here.. how do you know which power supply will work with your choice of mobo, graphics card, etc.? I want to order this PC Power & Cooling - it has a 6pin GPU connector.. very confused!
http://www.newegg.com/Product/Prod [...] 6817703009
PC Power & Cooling S75QB 750W ATX12V / EPS12V SLI NVIDIA SLI Certified (Dual 8800 GTX and below) CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
with: ASUS P5E LGA 775 Intel X38 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813131219
and: Matrox M9120 Plus LP PCIe x16 http://www.matrox.com/graphics/en/ [...] pluslpx16/
Thank you,
Mike
Sponsored Links
That PSU will easily work with those components with no problem and PC Power is a quality brand. Make sure that you choose a case that will handle it.
Reply to cmichael258
Were you wanting to run two of those cards?
The Matrox does not need the power connector from the PSU, it does not need that much power.
The PSU you mention is a very good one, but it's probably more than you need.
Reply to Proximon
Yes, eventually two. What do you recommend? Thanks a lot!
Reply to mikem_94
I do not see the power requirements listed at Matrox. I do know that PCI-E is limited to 150W... So that is a max of 300W between the two cards.
http://www.newegg.com/Product/Prod [...] &Tpk=550VX
This PSU will give you many years of worry free operation, and should power any additional devices in your case with ease.
Reply to Proximon
Ohhh get the red one it's better cause it's red.
http://www.newegg.com/Product/Prod [...] 6817341011
The best PSU is PCPower and cooling. Yes for you right now it is overkill. But you will be able to use it in another build later down the road.
The price is unbeatable, so get it.
Reply to bobbknight
There are 598 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
