I dont know which video card to buy please help me to select a nice video card to play my FSX game
My Spech
Dimension E521
AMD Athlon 64x2 5600 2.8GHZ
2GB RAM Upgrade to 4GB
BGF 8600Gt OC 256MB
Hercules 500w Power Supply
And I Have A Cooling Fan On The Back Of It
In most cases the 9600GT is faster. The 9600GSO is the same as the 8800GS (just renamed really) and right now you can probably get them cheaper thanks to competition from the 4670. If you can afford to spend a few more bucks though, spring for an 8800GT.
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
The 9600GT SSC will rape that 8800GS. the 9600GT is a re-branded 8800GT just 5% slower.
Go for the 9600GT regular edition and save some bucks, no need for SC or SSC editions.
It would be better to get the 8800GTS 512Mbs though as it will save you money and its faster. Its basically an improved 8800GT.
------------------------------[quote:e59fbc2129="Buzby"]Should I upgrade my Ram from 256mb to 1 mb?[/quote:e59fbc2129]
[quote:e59fbc2129="chips2481"]Geforce is like a cheaper made quadro card[/quote:e59fbc2129]
ASUS Striker Extreme
Intel E6600 @ 3.15Ghz
Reply to slim142
No offense, but you're full of it. 9600gt's g94 core with 64 stream processors is exactly half of 8800gts's g92 core with 128 stream processors, and a little more than half of 8800gt's g92 core with 112 processors (16 disabled). It does run at higher stock clock, but this also limits overclocking headroom, and gap in performance is big. How is it a rebranded 8800gt? They run on completely different gpus (g92-g94).
Message edited by dagger on 09-26-2008 at 11:00:36 PM
Back to the original question. The 9600GSO and the 8800GS are the same... look at core and memory clock speed when you are comparing them. The best one of "these" cards that I could find for the price is:
http://www.newegg.com/Product/Prod [...] 6814150276
