Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help!!!! Need help connecting 9800 gtx+
Forum Graphic & Displays : Graphics Cards - Help!!!! Need help connecting 9800 gtx+
so i bought a new hp computer ( m8400f ). i succesfully replaced the power supply with a corsair 650W psu. and then i tried to install my new evga 9800 gtx+ superclocked version when i came across a problem. i believe my motherboard is an nforce 430, and the sata data cables going into the motherboard are not allowing my to connect the graphics card. when i unplug the 3 sata data cables (2 harddrives and dvd) from the motherboard the card fits just fine. but im pretty sure those need to be connected.. so i have no idea what to do to solve my problem. please help me.
http://i103.photobucket.com/albums/m159/pitchingdreams/4006157R_MV2.jpg
Sponsored Links
Move the cables to the bottom 3 SATA plugs. Then youll have just 1 under the video card, and you SHOULD be able to slightly bend the cord, but not too much. And if its simply the base of the cord that is too tall, well youre kinna screwed :( Unless you can figure out what those SATA cables go to, im assuming 1 for the hard drive, 1 for the DVD drive, and 1 for the media reader/card slots. You might be able to live without that last one, well unless you use it.
Message edited by spathotan on 09-27-2008 at 04:46:47 AM
------------------------------ http://valid.canardpc.com/cache/banner/547515.png
Intel Xeon X3370 @3.6ghz Under Enzotech Extreme-X,EVGA GTX 285 SC, 4GB Mushkin Ascent eVCI @ 1066mhz, Gigabyte P45 UD3P
Reply to spathotan
its a 2 slot card so it covers pretty much all sata slots, and bending doesnt work.. i tried for a lonng time
Reply to numb3rspunk
Ahh yeah, duh. I lost thought by looking at your red drawn "card". Well, other than that there really is nothing you can do. Hopefully you can return the card.
Reply to spathotan
- 1 +
You'll need an expansion card for the extra SATA ports.
http://www.newegg.com/Product/Prod [...] rder=PRICE
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
im a total noob, so can u be a little more detailed about what i would have to do for that expansion card thing?
- 0 +
Buy it, plug it into PCI slot, connect the drives to the SATA ports on the card instead of to the blocked SATA ports on motherboard. :p
Reply to dagger
^ +1
I forgot all about those things. Sorry for my bad advice numb3rs
Message edited by spathotan on 09-27-2008 at 05:22:08 AM
Reply to spathotan
this are my specs from online: 1 PCI (occupied), 2 PCI Express x1 (two available), 1 PCI Express x16 (occupied).
the last one is obviously occupied by the graphics card. sooo um, does it go into the pci or pci express x1 ? if it goes in the pci slot, what do i do? is whatever is occupied in that slot neccesary?
- 0 +
HMMMMMMM,,If you have the $$$ for a dual slot 9800gt and an upgraded psu why not go the whole hog and buy a real computer,or get one built for you to your specs either locally or at newegg,you will find plenty of useful suggestions here [Tom's] just for the asking,it looks like you are trying to put together a gaming rig,i think if you look into it you might find out that the Hp mobo may have some limitations,some of which you are already experiencing
and,,there may be other "gotchas",as you can see that mobo was never designed for a dual slot video card,who knows it might not even like your new psu,could be too much for the design if you look at the power circuitry is does not seem to be multi phased at all as in no choke coils at all,,personally i would get rid of it asap,mostly because everything is all cramped together and there is no room to work or add anything,,,..
Really if you want to spend the money and have it to spend ask around here at Tom's,you'll be glad you did,and wind up with a much better and "funner" experience..:)
Message edited by dokk2 on 09-27-2008 at 05:26:42 AM
Reply to dokk2
Well the online specs and the design of the pic you have are different, the pic shows 2 PCI and 1 PCIe 1x. The PCI slots are the long white ones, PCIe is the tiny white one, which will be blocked by the 9800GTX. Youll have to open the case up and see if one of those 2 PCI slots are open.
Reply to spathotan
- 0 +
Strange, I'm not seeing 2 pciex1 and one pci on that picture, rather 2 pci and 1 pciex1. But anyway, those are available in both flavors.
PCI:
Pciex1:
Reply to dagger
thats not really an option. the computer was a gift. and i spent 300 on a psu and graphics card, and thats all i was willing to spend. i never expected this problem seeing as i knew nothing of how to build a computer before this. but i knew i wanted to do some gaming and researched about how to go about that. i already have a great pc, and i realized all i needed was a new graphics card and a psu to go with it. i encountered this problem, and the solution is not to start over from scratch, its to bypass the problem somehow.
the picture was just an example, sorry if i made it seem as if it were my exact motherboard
dagger, of the pci express x1 would you recommend if i need to insert 3 sata data 7 pin cables into it?
- 0 +
All the ones on there have at most 2 internal SATA ports, so you'll need 2 cards for 3 drives. It'll be good if you can fit 1 drive onto the motherboard's SATA port.
Reply to dagger
No, they only have 2 internal and 2 external. Unless you can find one that has 3 internal, or you have enough slack to pull a cable out the back from one of the expansion slot covers and hook it up that way.
Reply to spathotan
- 0 +
You can also put that spare IDE port to use:
http://www.newegg.com/Product/Prod [...] 6812197005
Reply to dagger
i was trying to look up solutions before i came here, and i stumbled upon sata data 7 pin cables that had 90 degree ends. i think that the lower most plug might be able to squeeze in there with a 90 degree end.
but i have no idea if its supposed to be a right angle one or left angle one, do you think one of those 90 sata cables and one card with 2 internal sata slots will solve my problem?
Hah, you should have gotten a 4850. Anyway just put the expansion card in the bottom most slot. The firmware on the expansion card should let you boot off whatever you connect to it hassle free. If you don't want to wait and your town is lucky enough to have a CompUSA that was bought out by Tiger Direct, then you should be able to pick up one there pretty cheap.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
Anyway if you have 4 SATA devices, and that picture of your board is accurate, then you can get this thing from the egg
http://www.newegg.com/Product/Prod [...] 6815280003
Reply to megamanx00
i live in miami, so theres a million tiger directs here. i plan to go there tomorrow morning and hopefully my problem gets solved by the afternoon
no the picture isnt accuate, i have 3 sata devices, and no open pci slot, but i do have 2 open pci express x1 slots
Then get a PCI-E 1x card and put it in the lowest slot. Make sure it has enough SATA connections to connect all your devices.
Reply to megamanx00
Thats the problem megaman........PCIe SATA cards only have 2 internal ports.
Reply to spathotan
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
