I have done some system builds in the past but i have never had the result i would have liked with the new computer so i wanted to make sure i was putting some good parts to good use in this case.
Here is what i have decided on so far, please let me know of anything i should change:
Toss the rest of your parts in with those. That will get you far more pperformance and stability. Your chosen power supply is quite poor and would likely die trying to power that 4870... if it even had the connections to try.
Message edited by Proximon on 09-02-2008 at 01:31:48 PM
Cheers for your recommendations, i made up the list below from what you have recommended. Do you think it would be better if i got some sort of extra cooling? (CPU for example) just coz i have read a little about the heat the HD4870 produces.
Thermaltake Smart Case Fan 12CM
Western Digital 500G SATAII 7200 rpm HDD(16Mb Cache)
Thermaltake Soprano DX Steel with Window Black NO Power Supply
LG H20NS10 SATA 20X+- Super Multi DVD Rewriter Black with Software
Intel ATX E8400 CORE 2 DUO /3.0GHz/6MB/1333FSB/LGA775
It's quite good for what you have to work with down under. If you can swing the 640Gb version of the HD, it's faster. Seagate 500Gb otherwise, if available.
I am just replying to my own post again as i had some more questions for anyone that can help me...
With the rig i stated above would that be good enough to run alot of the high end games (at a relatively high setting with 1680x1050 res) comming out soon?? ie.. Farcry 2 and Crysis Warhead etc..
because i was considering that i should change a few parts so i could add upgrades along the way ie. Running 2 4870s in crossfire... But would this mean i should consider a better case and better cooling?
