Tom's Hardware > Forum > Graphic & Displays > ATI > ASUS 4870 at 60C when ideal and 100% Fan speed
Forum Graphic & Displays : ATI - ASUS 4870 at 60C when ideal and 100% Fan speed
Hi Guys,
I was wonderign what can i do to lower my GPU temperature.
I have the ASUS 4870 and at 100% fan speed, it is at 55-60C.
My CPU is 2.2 Quad phenom and have the Corsair 650W PSU. I leave my computer tower open as well to get more air flow going. Is it too hight to have an idle temperature of 60C (most of the time) when no load is being imposed on the GPU and when no special cooling system is installed, purely using the fan on the GPU?
Thank you very much for your help!!!
Sponsored Links
100%, that thing must sound like a jet, anyway that is far too hot for idle with 100% fan speed.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
- 0 +
Thats the thing, i saw videos of 100
% fans on the 4870 and they do sounds very loud. Mine doesnt at 100. Could it be a bad driver installed?
Reply to xelonth
How have you set the fan to 100%? Download GPU-Z and find out what is really going on. http://www.techpowerup.com/downloa [...] 0.2.8.html
Reply to No1sFanboy
It really should sound very loud, if it isn' then it probably isn't actually at 100%. I am assuming you are using the manual profile editing to increase the fan speed and you have overdrive unlocked yes?
- 0 +
Hi,
First of all, i am running windows Vista 32 bit. And every time i boot my computer it tells me that ATI Catalyst is not being supported but i can still open it. I have to switch to advance mode every time. I instaleld the drivers along with the ATI Catalyst so i am not sure if everything is being supported properly. I did choose to download the 32 bit VIsta version (the one i have).
I went t ATI Overdrive under the Catalyst and unlocked it.
Left GPU at 750 and Memory clock at 900.
With my case wide open the temperature is 55C
I then used ATI EXPERTool to set the fan to 100% and when i go to GPU-Z it tells me its running at 100% but at 2600 RPM. AFAIK, 100% should be around 4000RPM.
Also, when i am not playing any games, i want to make the graphics card to be as quiet as possible. Is there a way i can set to to such a lot level of activity just to be able to write in WORD or something so i wont even hear the fan even a bit and the temperature would be very low? (I wouldnt care to have extremely low performance when using WORD as long as it will be super quite).
So why would it say 100% fan but not full RPM?
Thank you very much.
P.S. how can i upload images here?
Thank you very much!!!!
Reply to xelonth
something clearly ain't working right with the drivers. try re-installing them if you have not already and make sure you have administrators rights.
i would search for , then use the profile editing way of controlling the fanspeed.
I use rivatuner to set my fan speeds, and it works pretty well.
Reply to San Pedro
- 0 +
Yeah, use ATITool 0.27 Beta 3 or RivaTuner v2.11 to set fan speeds.
Go into add remove programs and uninstall CCC, it's flaky pig crap IMO.
Reply to Zorg
- 0 +
Same thing, they all show 100% at 2600 RPM. And tried reinstalling drivers. Nothing helps
Reply to xelonth
There are 1257 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
