Solved
Problem installing Win XP
Last response: in Storage
What can I do to fix the problem of trying to install Win XP, when ever I get to where SETUP IS STARTING WINDOWS it stays frozen I have tried everything I know which is not very much,any help would be very much appreciated,or if you can advice me on what software to purchase to fix this problem,by the way I am trying to install this on a SATA 640 gig HDD, thank you!!.
More about : problem installing win
Best solution
try booting from your cd/dvd drive with the windows disk in the drive, instead of booting from the hard-drive. see what happens. you just gotta change the boot priority probably in your bios from "hardrice" to "cd/dvd drive" . some PC's, you can hit an F key during initial boot to change the settings.
Ask the community
