Hello to all members of TH,
Here are some basic wuestions that i have, can some one please take some time and exaplain these for me.
(1) How do you know which Intel CPU is for you, for example if i am a gamer and playing FarCry, do i need a dualcore or a quodcore, how will i know this that a game will be able to play more than 2 cores.
(2) Buying a 64bit O/S will it make the use of 4 Cores? Or can a 32 Bit O/S also use 4 Cores.
(3) if i have a 32Bit O/S and i have 2GB of RAM, and 2GB of VRAM, will it be worth buying 64bit due to the limitations on the O/S? Or can a 32Bit O/S use 2GB of RAM and 2GB of VRAM as well.
(4) Every motherboard has a chipset for example, P35,P45 X48, etc, what are these supposed to mean? I mean the numbers not what a chipset is.
For now these are some of the questions, that i have.
Thank you for taking your time in reading this thread.
Have a good day.
Have a good day.
