Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > I have a ga-ep45-ud3p and i have the power error please help!
Forum Motherboards & Memory : Gigabyte - I have a ga-ep45-ud3p and i have the power error please help!
what happend was that a plug melted in dvd drive and my mobo started to give me the power error beep :fou: and i tried a lot of things but it wont help!! please tell me what i should do or if i should rma it help much appreciated!!!!!!!
Sponsored Links
plug melted in the dvd drive....sounds like some things got fried. You will have to get a new psu (get a quality brand like corsair, pc power and cooling, ocz, etc to avoid this happening again) and hope that it didn't take any other components with it. If you get a new psu you can check the rest of the components with it but i wouldn't be surprised if your mobo etc got fried.
Reply to kyeana
yeah i think my mobo is fried and i just got it today and im almost in tears!!! i guess ill have to buy a new psu and rma the mobo.
Reply to killshot95
Here is a link to an inexpensive power supply tester:
http://www.newegg.com/Product/Prod [...] 6899887102
Unless the plug that melted was the actual IDE conector, and not the 4-pin molex supplying it power (and I don't see how that could happen), it's probably unlikely that you fried your MOBO; much more likely that your power supply is cooked.
Reply to bilbat
Get a new psu and check everything else (like the mobo) before throwing money away on things that may or may not be dead.
Reply to kyeana
yeah my psu is totally fried but i checked my mobo and its fine cuz i used my freinds psu and the mobo is fine but im getting the corsair 750wtx psu
Reply to killshot95
that is a solid psu, should last you for a good long while and not melt on you ;)
Reply to kyeana
thx for the help guys :D
Reply to killshot95
There are 1211 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
