Ok, So it's almost Christmas and what better excuse is there to spend money? In my present location my CPU temps are too high when overclocked. I plan to solve the issue with this water cooling system.
Here are the parts so far.
The Fans:
Scythe SY1225SL12M 120mm "Slipstream" Case Fan - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185058 $8.99 X 3
I have looked at the Yate Loon fans at DangerDen.com and the Scythe are a little quiter and push a little more air while only costing a few dollars more. I am open to suggestions on that
The Pump:
Swiftech MCP655 12 VDC Pump Liquid Cooling System - Retail $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108082
I've noticed DangerDen has the Lang D5 fixed speed pump for 20% off so I may get it from there, as well.
The Rad:
Swiftech MCR320-QP Quiet Power radiator - Retail $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108098
The radiator has some decent reviews. I've noticed Conundrum has recommended Skinnee Labs as a great source to look.
CPU Block:
Swiftech Apogee GTZ Extreme Performance CPU water block - Retail $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108110
I've read the reviews on Newegg which say the retention bracket was stripped out. Has anyone confronted this issue? I have come to distrust Newegg reviews.
I also need a reservoir and some tubing
I've considered this:
http://www.frozencpu.com/products/8336/ex-res-144/Swiftech_MCRES_Micro_Rev_2_Small_Form_Factor_High-Flow_Reservoir_12_ID_and_38_ID.html?tl=g30c97s165
As far as tubing goes, I'm going 1/2" throughout the loop. Can vinyl tubing be purchased at stores like Home Depot/Lowe's?
For the coolant, I'll use distilled water and some additive, again, I'm not sure what additive to use. Please suggest a great brand/type.
That's all I have found so far and would like to order everything soon.
Here is what I'd like to do with my P182
Edit: for some reason the link won't paste and work...weird
If interested to see what I'd like to do, Google "antec p180 680i water cooling" and it should be the first link at Hard Ware Canucks...
The Fans:
The Pump:
The Rad:
CPU Block:
