Some people find that PSUs that are "just enough" for a card make a card perform sub-par. Upgrading their PSUs results in better performance. PSUs that aren't strong enough to run certain cards reboot randomly or won't POST at all.
I don't believe that's true, I don't think that the cards throttle based on power availability.
However, if your PSU already supplies enough power, it won't make any difference.
Nah, the quality of the PSU will affect stability, not performance. We generally recommend higher-than-necessary wattage PSUs because PSUs are most efficient (produce less heat, quieter) at around half of their maximum rated output.
Ive seen where an underpowered psu will hinder a gpus performance, BUT, thats more of a freak thing then whats already been mentioned, such as stability etc. Eventually, if its just on the edge of booting up, and effecting the gpu, it wont be long before you start seeing stability issues etc, as the psu is overworking/heating, and will soon weaken
------------------------------I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
I have personally seen a weak/poor PSU result in weird performance with my system. A few years back I had dual 7800 GTs and when I ran the CS:S video stress test, I got like 90-something fps with 1 card. When I turned on SLI I got 70s, and it looked very jittery/awkward. I swapped my PSU from a 550 to a 750 and my frames jumped to 150.
As JDJ said, that's a freak occurrence so don't expect to really see that too much, but it is definitely within the realm of possibility.
