Solved
Hard disk problem
Hello,
I have a computer that runs windows xp home edition on it and my hard disk crashed so I had to install a new one. How do I format the new one?
4 answers Last reply Best Answer
More about hard disk problem
  1. My computer didn't come with a windows installation cd. Is there still a way to format the new one?
  2. Best answer
    Most commercial computer vendors these days don't give you an operating system Cd/DVD when you buy the system (but it can usually be purchased for an addition fee). The vendors usually create a hidden partition on the HDD, which can be accessed from a boot menu to reinstall the OS if necessary, and it's usually an image file that contains the OS and device drivers for the system as it was supplied from the factory.
    Since your HDD crashed, you might try and contact the vendor and see if they'll sell you the Cd/DVD for your system, although, since it's Win XP Home, then it's most likely an older computer and out of warranty, but you can still ask. You might also ask if they can sell you a newer version of the OS (Vista or Win 7, but they may not. Be sure and ask about compatibility as well). Otherwise, your best bet would be to purchase another version of the OS. Here's a link for Newegg that shows the various versions of MS OS Home Edition software:
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2060350368+1179212227&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=368&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
    Be aware that if you purchase an OEM/System Builders version, then that version is only valid for the life of the motherboard that it was installed on, and you would need to purchase yet another version if you ever decided to upgrade (you don't specify whether this is desktop or laptop computer). Microsoft's license for OEM/System Buiders version is only valid for the computer that it was first installed on.
    Here's another link for the FULL version of all the current MS operating systems:
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2060350368+1179212716&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=368&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
    The full version would be transferable to any computer you chose to install it on but only valid for use on one system at a time.
    Last but not least, here's a link for The Ultimate Boot CD, which contains quite a few utilities that may help solve problems with your computer:
    http://www.ultimatebootcd.com/
    You'll have to format your new drive from an operating system CD that supports NTFS, I.E., Win XP, Vista, Win 7.
    Good luck and I hope this has been helpfiul
  3. Today we ordered windows xp Home Edition installation cd from Tiger Direct. We should receive it within a week.
    Thank you for your suggestions. I hope to have this computer up running again soon.
  4. Best answer selected by Bristo.
Hard Drives Computer Windows XP Storage Product
