I'm going to be buying a core i7 pretty soon and I'm trying to decide if I should upgrade my sound card or not.
I have an X-fi fatality Pro that runs using a regular PCI slot. I'll be keeping my old video cards (dual evga 8800 GTS' in SLI). Which keeps my choice of motherboards kind of slim.
The reason I'm even asking the question is because I have reason to believe there might be a problem with the sound card, but I'm not positive if its the sound card, or the PCI slot on the motherboard.
The bottom line is that I don't know if I should try to use my old sound card (and buy the nessesary motherboard), or should buy a new sound card that uses PCI Express, and a motherboard that will make it work?
Sorry this might not be clear, but if you need some clarification just let me know. Thanks!
